1 - 9 of 9 Posts
Old Timer
I installed gDesklets, but I managed to get one (a menu bar where you can activate minamized programs) half off the screen. The way it is, if I right click it, all I can get is the menu for the application minimazation settings (is minimazation a word?), and not the desklet settings so I can remove it! It looks like crap sticking out from the side of my screen, and its not even usefull where it is! Please help!
I seem to remember that you can right click on the gDesklets widgets (for lack of a better term) and lock/unlock them from the desktop. So right click > unlock > then drag around the desktop.
you mean the bar is off the screen?<br><br>
you can right click, remove desklet, then re add the desklet, and you can position it in a nicer place.<br><br>
or hold your windows button (between ctrl and alt) and middle click drag it to a nicer position... or try alt+f7 to move it.<br><br>
if it's a single 'starter' thats off the screen, you can remove starters by right clicking them, or drag them around with left click drag, along the bar.<br><br>
hth
Old Timer
Discussion Starter #4
<div>Originally Posted by <strong>SoaDMTGguy</strong></div>
<div style="font-style:italic;">The way it is, if I right click it, all I can get is the menu for the application minimazation settings (is minimazation a word?), and not the desklet settings so I can remove it!</div>
</td>
</tr></table></div>
^I cant click on it, because I dont get the settings for the desklet, just for whats ON the desklet. Hold on, I'll post a screen shot showing what I mean.
Old Timer
Discussion Starter #5
<img alt="" src="http://www.rigshowcase.com/img/332ROinu/7239.jpg" style="border:0px solid;"><br><br>
Ok, as you can see in this screen shot, the bar in the middle right that has program bars on it is what I am trying to remove. However, when I right-click it, all I can bring up is the box that you can see with options for the window list, and not the desklet its self!
hmmmm interesting...<br><br>
can you please open a terminal... and type this out (without the $)<br><br>
$cat .gdesklets/displays<br><br>
then post the output of that...
Old Timer
Discussion Starter #7
Ok, I fixed it! I ended up reinstalling gdesklets, and that worked.
Reactions: theRemix
rep+ for not giving up <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Old Timer
Discussion Starter #9
<div>Originally Posted by <strong>theRemix</strong></div>
<div style="font-style:italic;">rep+ for not giving up <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"></div>
</td>
</tr></table></div>
Heh, thanks <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
Its amazing how much you learn when you have nothing better to do... <img alt="" class="inlineimg" src="/images/smilies/rolleyes.gif" style="border:0px solid;" title="Roll Eyes (Sarcastic)">
Reactions: dangerousHobo
1 - 9 of 9 Posts
