I was putting together an AMD build for a friend. This is the best deal I can find on a mobo with USB 3.0 & SATAIII, my friend's only concerns.
It is a great deal at $64.99. $58.49 is too good. You can get an additional $10 rebate from signing up for a trial at freeshipping.com, an option you will see after checkout. $48.49 is wicked. (surely an unmatched sub-$100 mobo/cpu combo with that Microcenter Phenom II x4 830?).
Link:
10% Savings Code:
Manufacturer's website for the ASUS M4A88T-V EVO/USB3:
This ASUS M4A88T-V EVO/USB3 Socket AM3 ATX motherboard offers fast performance for all your gaming and multimedia applications!
The M4A88T-V EVO/USB3 features the AMD 880G + SB710 chipset and supports up to 16 GB of DDR3 RAM! Experience powerful video and audio performance with the ATI Radeon HD 4250 integrated graphics with 128MB integrated SidePort memory and Realtek ALC892 8-channel HD audio. Connect to a high-speed Broadband Internet via Realtek RTL8111E Gigabit Ethernet!
Expand with the two PCI Express x16 slots that support ATI CrossFireX, a PCI Express x1 slot, and three PCI slots. With HDMI, DVI-D, and VGA ports, you're free to use nearly any type of display. Five Serial ATA 3.0 Gb/s connectors with RAID support allow you to connect high speed storage drives with up to 3.0 Gb/s data transfer rates.
With up to ten USB 2.0 ports and two SuperSpeed USB 3.0 ports, you have plenty of room to connect your favorite peripherals. The M4A88T-V EVO/USB3 supports AMD Phenom II and Athlon II AM3 processors with HyperTransport technology up to 5.2 MT/s!
Upgrade to this ASUS M4A88T-V EVO/USB3 ATX motherboard today!
Features/Specifications:
ASUS M4A88T-V EVO/USB3 AMD 880G Socket AM3 ATX Motherboard
General Features:
ATX form factor
Socket AM3 architecture
Supports HyperTransport 3.0 (up to 5200 MT/s)
Dual-channel DDR3 memory architecture
Supports up to 16 DDR3 2000(OC)/1333/1066 MHz DDR3 SDRAM
Integrated ATI Radeon HD 4250 w/128 MB SidePort memory
Integrated Realtek ALC892 8-channel HD audio
Integrated Realtek RTL8111E Gigabit Ethernet LAN
Integrated VIA VT6308P IEEE 1394a controller
Five (5) Serial ATA 3.0 Gb/s ports with SATA RAID 0, 1, 10, JBOD
One (1) IDE (UDMA 133/100/66)
ATI CrossFireX technology
ASUS Hybrid Processor - TurboV EVO
ASUS Turbo Unlocker
ASUS Auto Tuning
ASUS TurboV
ASUS CPU Level Up
ASUS GPU Boost
ASUS Hybrid Switch
ASUS Core Unlocker
ASUS Turbo Key II
ASUS 8 +1 Phase Power Design
ASUS EPU
ASUS Turbo Key
ASUS MemOK!
ASUS Anti-Surge
ASUS Express Gate
ASUS Quiet Stylish Fanless Heat-sink Thermal solution
ASUS Fan Xpert
ASUS EZ DIY
ASUS O.C. Profile
ASUS CrashFree BIOS 3
ASUS EZ Flash 2
ASUS MyLogo 2
24-pin ATX power connector
8-pin ATX12V power connector
Lead-free components (RoHS compliant)
Expansion Slots:
One (1) PCI Express 2.0 x16 slot (x16 mode, blue)
One (1) PCI Express 2.0 x16 slot (x4 mode)
One (1) PCI Express 2.0 x1 slot
Three (3) PCI slots
Four (4) 240-pin DDR3 DIMM slots
I/O Ports:
One (1) PS/2 port (keyboard)
One (1) SPDIF out (optical)
Four (4) USB 2.0 ports
Two (2) SuperSpeed USB 3.0 ports
One (1) IEEE 1394a (FireWire) port
One (1) eSATA port
One (1) HDMI out
One (1) DVI-D
One (1) 15-pin VGA
One (1) RJ-45 Ethernet jack
Line in, line out, microphone 3.5 mm audio jacks
Side, rear, c/sub 3.5 mm audio jacks
Internal Headers:
One (1) Front panel header
One (1) Front panel audio header
One (1) SPDIF out header
One (1) 9-pin Serial/COM header
Three (3) USB 2.0 headers (six ports total)
One (1) IEEE 1394a FIreWire header
One (1) 4-pin CPU fan header
One (1) 3-pin chassis fan header
One (1) 4-pin chassis fan header
Regulatory Approvals:
FCC
CE
WEEE
RoHS compliant
Package Includes:
User Manual
I/O shield
Two (2) Serial ATA data cables
One (1) IDE cable
Additional Information:
Notes:
Model: M4A88T-V EVO/USB3
Product Requirements:
ATX case
Supported processor
Supported RAM
Rest of system
I/O shield
edit: corrected link
Link:
http://www.geeks.com/details.asp?invtid=M4A88TDV-EVOUSB3-PB2R&cat=MBB
REDTAGDEALS
http://www.asus.com/Motherboards/AMD_AM3/M4A88TV_EVOUSB3/
General Features:
ATX form factor
ASUS Turbo Unlocker
ASUS Auto Tuning
ASUS TurboV
ASUS CPU Level Up
ASUS GPU Boost
ASUS Hybrid Switch
ASUS Core Unlocker
ASUS Turbo Key II
ASUS EPU
ASUS Turbo Key
ASUS MemOK!
ASUS Anti-Surge
ASUS Express Gate
ASUS Fan Xpert
ASUS EZ DIY
ASUS O.C. Profile
ASUS EZ Flash 2
ASUS MyLogo 2
Expansion Slots:
Three (3) PCI slots
I/O Ports:
One (1) eSATA port
One (1) HDMI out
One (1) DVI-D
One (1) 15-pin VGA
Internal Headers:
FCC
CE
WEEE
RoHS compliant
Package Includes:
User Manual
I/O shield
One (1) IDE cable
Notes:
ATX case
Supported processor
Supported RAM
Rest of system
I/O shield
