1 - 20 of 21 Posts
New driver, titan already not supported??
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.14-beta-driver.html
New in GeForce 314.14 Drivers
Performance Boost - Increases performance by up to 23% for GeForce 400/500/600 series GPUs in several PC games vs. GeForce 314.07 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here is one example of measured gains:
GeForce GTX 680:
Up to 23% in Sniper Elite V2
Up to 9% in Sleeping Dogs
GeForce GTX 680 SLI:
Up to 22% in Sniper Elite V2
Up to 14% in Sleeping Dogs
Up to 9% in StarCraft II
Up to 5% in Call of Duty: Black Ops II
Up to 5% in Deus Ex: Human Revolution
Up to 5% in Just Cause 2
Up to 4% in The Elder Scrolls V: Skyrim
Up to 4% in Batman: Arkham City
SLI Technology
Updates SLI profile for Resident Evil 6
Adds SLI profile for Sniper Elite: Nazi Zombie Army (delivered via NVIDIA Update)
Additional Details
Installs PhysX System Software 9.12.1031.
Installs HD Audio v1.3.23.1
Includes support for applications built using CUDA 5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
GeForce 600 Series
GeForce GTX 690, GeForce GTX 680, GeForce GTX 670, GeForce GTX 660 Ti, GeForce GTX 660, GeForce GTX 650 Ti, GeForce GTX 650, GeForce GT 645, GeForce GT 640, GeForce GT 630, GeForce GT 620, GeForce GT 610, GeForce 605
GeForce 500 Series
GeForce GTX 590, GeForce GTX 580, GeForce GTX 570, GeForce GTX 560 Ti, GeForce GTX 560 SE, GeForce GTX 560, GeForce GTX 555, GeForce GTX 550 Ti, GeForce GT 545, GeForce GT 530, GeForce GT 520, GeForce 510
GeForce 400 Series
GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460 SE v2, GeForce GTX 460 SE, GeForce GTX 460, GeForce GTS 450, GeForce GT 440, GeForce GT 430, GeForce GT 420, GeForce 405
GeForce 300 Series
GeForce GT 340, GeForce GT 330, GeForce GT 320, GeForce 315, GeForce 310
GeForce 200 Series
GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250, GeForce GTS 240, GeForce GT 230, GeForce GT 240, GeForce GT 220, GeForce G210, GeForce 210, GeForce 205
GeForce 100 Series
GeForce GT 140, GeForce GT 130, GeForce GT 120, GeForce G100
GeForce 9 Series
GeForce 9800 GX2, GeForce 9800 GTX/GTX+, GeForce 9800 GT, GeForce 9600 GT, GeForce 9600 GSO, GeForce 9600 GSO 512, GeForce 9600 GS, GeForce 9500 GT, GeForce 9500 GS, GeForce 9400 GT, GeForce 9400, GeForce 9300 GS, GeForce 9300 GE, GeForce 9300 SE, GeForce 9300, GeForce 9200, GeForce 9100
GeForce 8 Series
GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS 512, GeForce 8800 GTS, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8600 GS, GeForce 8500 GT, GeForce 8400 GS, GeForce 8400 SE, GeForce 8400, GeForce 8300 GS, GeForce 8300, GeForce 8200, GeForce 8200 /nForce 730a, GeForce 8100 /nForce 720a
Hmm, no mention of anything Tomb Raider. Maybe it already plays well on current drivers?
Release notes PDF also mentions Tomb Raider in its highlights. SLI profile for it has been added, apparently.
These crap drivers have the same stupid bug that 314.09 did. If you use manual fan 68% or higher, your cards will downclock. My boost normally is past 1300. With manual fan past 68%, my boost is suddenly 1020mhz.
Back to 314.07. Screw that nonsense.
waiting for Driver update
just installed to try TR , and the game crashed 3 times with me however the performance was smooth @ 1440p
gonna see how crysis3 plays
just downloaded these but waiting for others to come back with results!
anyone tried crysis3 with these? I thought it said something about an updated SLI profile for it
In the release notes it looks like Nvidia doesn't support 1920x1080 at any refresh rate above 60? Seriously?
If its crashing for you turn Tessellation off, it fixed all crash issues i had. Did it run fine for you with the TressFX hair quality?
When i first tried it i maxed it out with both Tessellation and TressFX enabled but i had poor performance around 30 FPS when the camera was zoomed in on Laras head and then at some point in the game itd start crashing all the time. Tried turning TressFX off first which fixed the FPS drops and i got stable 60 FPS but the game would still randomly crash on me so i then disabled Tessellation and that fixed all my problems i had with the game, runs smooth and works stable since.
yeah it was only tessellation causing the crashes , even with tressFX on the game is playing smooth @ 1440p
1 670 is enough @ 1080p but the game needs more optimization to play perfect with no dips
Not really, I play it at 1680x1050 everything maxed out with tessellation off and i get 60 FPS only when the game isnt showing Laras head from up close. TressFX is such a hog it halves my FPS. Running on my sig rig, CPU OCed to 4.2 Ghz and GPU @1254/1728 Mhz....
They DO list the Titans for this driver.
Supported Products
ION (Desktops)
ION
ION LE (Desktops)
ION LE
GeForce 600 Series
GeForce GTX TITAN, GeForce GTX 690, GeForce GTX 680, GeForce GTX 670, GeForce GTX 660 Ti, GeForce GTX 660, GeForce GTX 650 Ti, GeForce GTX 650, GeForce GT 645, GeForce GT 640, GeForce GT 630, GeForce GT 620, GeForce GT 610, GeForce 605
These actually made the stutter worse for me. I had to restore default settings in Nvidia control panel and use the in-game Vsync option along with Afterburner to limit the frames to 60. Doing this, BF3 is smoother than it's ever been.
I haven't played Farcry 3 in a while but with the latest drivers the game didn't dip under 60fps in a big fight. Very impressive in my opinion.
Out of curiousity, what settings do you use?
My system is similar to yours. Noticed with alpha to coverage enabled with 2xAA , I get some nasty dips at strange times.
1 - 20 of 21 Posts
