Geforce 6150SE nforce 430
10227 Views 13 Replies 5 Participants Last post by  arkheii
Should this card show 0 Mhz for memory in gpu z?
1 - 14 of 14 Posts
ya. the memory of the onboard is taken from system memory
So will there be a major increase in performance if i go from 1 gb system memory to 4 gb system memory?
not a major boost but a boost.
I have this thing in an emachine that has a 200w power supply and only a PCI x1 slot. Is there another card that outperforms this one that i can upgrade to?
there are few cards that can use that bus (PCI X1)
are you sure there's no PCI, PCIe x16 or AGP slots on it?
EDIT: the powersupply is a little weak to put a powerful videocard on but you might get away with a smaller one
Have you looked in it? No way it only has only one slot and it's a 1x slot.
i checked and its only the pci express x1 slot
no pci slots?
just the pci express x1 and they placed a modem in it. So what gpu upgrade can i do?
x1550
Originally Posted by whe3ls
x1550
Is this the one?
http://www.newegg.com/Product/Produc...82E16814161197
and can the 220w power supply handle it and this
http://www.newegg.com/Product/Produc...82E16819103298
along with 2x2gb memory, a 160 gb 7200 rpm hard drive and a dvd drive?
Try to make sure if the board can use that x1 slot for graphics, otherwise you will waste money buying an x1 card that it can't use.
Anyway, this might interest you: Albatron 9500GT http://www.overclock.net/hardware-ne...-pci-e-x1.html
1 - 14 of 14 Posts
