Geforce 6150SE question?
1244 Views 8 Replies 7 Participants Last post by  Shooter116
Should i be getting 5 fps with this card and an amd athlon 2650e @1.6 ghz with 1gb ddr2 800 mhz mem? Also i ran 3d mark 06 and got 303 lol
1 - 9 of 9 Posts
What are your running to get the 5fps value?
A game or a test in 3DMark?
I believe that the 6150e is an integrated card, so that score sounds about right to me. The processor isn't meant for gaming either.
i ran it on the tale of despereaux to get 5 fps and got 303 score in 3d mark 06
The computer would probably explode if you loaded Crysis.
I cant believe that this emachine cant even run such a low quality game. Its my little bro's pc that his step dad bought for him that i had nothing to do with! But he wants to play GTA San Andreas and i dont think it could even load it.
Correct, the 6150 is absolute crap.
It should handle GTA SA fine. Speed wise it will compare to the FX5200 or PCX5300 with dual channel, without dual channel it will preforme closer to a Geforce4 MX 440. I ran GTA SA on an FX 5200 at low settings 10x7 and it was about 30FPS. Also on a 6100 I ran a few games also, NFS:C ran on low 800x600 @ 31FPS, COD4 even ran low 640x480 @ 19FPS Average. So its not incable, just not meant for gaming on newer stuff. Older games it can do fairly well, MOH:AA ran @ High 12x10 on it, COD1 same.
Remember its a 2pipeline card, with 1 vertex shader and 1 rop though.
I have this chipset on my MB, came in my HP pc. I used to play counterstrike 1.6 and condition zero, at widescreen resolutions, but even then I was getting big FPS drops. I could barely play source and battlefield.
1 - 9 of 9 Posts
