GeForce 6600 (non-GT) temps...
794 4
hi! what temps should i expect with my GeForce 6600? my current temps are:
42c - idle
50c - load
if i'll overclock my card, what should be the highest temperature with the stock cooling installed? thanx!
1 - 5 of 5 Posts
I had an Inno3d GeForce 6600 and it used to idle at 57C and reach 72C under load (I used stock cooling and my room temperature was 24C).
As for the highest temp a GPU can withstand I would say don't go over 85C (if you can keep it below 80C you should be fine).
Hope that helps.
1 - 5 of 5 Posts
