1 - 6 of 6 Posts
i have a Gforce FX5200 Ultra 128MB. and i tried using cool bits to overclock it but when i download and install it, I right click on my desktop and then the settings tab, then the advanced button but then i have not got the option to choose my card like the instructions say. Any help would be greatly appreciated! I am new to this software (coolbits). I have an ASUS A7V8XX mobo w/ 1gb pc3200 ram 160 gb W/D HDD. and a AMD 2600+ processor w/300 watt PS. Thanks in advance. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I avoid aginst OCing the 5200Ultra, I had one, and while they have headroom the coolers on them suck, and even with a 5mhz OC mine would over heat. I suggest a newer AGP card.
Discussion Starter #4
I,m not sure about getting into coolbits main menu,not really sure how to be honest, but dont see anywhere to do it. It was just a 0.1mb download and it made the changes to the reg. automatically. I have changed the fan and modified the cooling on it, right now it actually don't even get warm so it stays almost cold. Thanks in advance.
I have a VF900 and I feel it's a terrible waste on my FX5200.<br />
<br />
Stock cooling should do fine. Firstly, have you installed your graphics drivers correctly? <br />
Verify that you have by rightclicking your desktop, and if there is a nVidia menu, it is installed correctly.<br />
Now, if you run with the 9x.xx drivers, you would have lesser problems. Just go into one of the menus and select "Classic Control Panel"
<div>Originally Posted by <strong>gonX</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1391989#post1391989"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I have a VF900 and I feel it's a terrible waste on my FX5200.<br><br>
Stock cooling should do fine. Firstly, have you installed your graphics drivers correctly?<br>
Verify that you have by rightclicking your desktop, and if there is a nVidia menu, it is installed correctly.<br>
Now, if you run with the 9x.xx drivers, you would have lesser problems. Just go into one of the menus and select "Classic Control Panel"</div>
</td>
</tr></table></div>
Agreed I used to have a 5200 and it was a horrible overclocker. Get you self a better agp card you can get a decent one for pretty cheap these days on newegg. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
1 - 6 of 6 Posts
