1 - 20 of 35 Posts
BGP is my favorite
At Best Buy its $70 and i just want a better graphics than i have i want to know if it'll play CS:S and some other games maybe with low settings or sumthing cuz this time i actually have the money
OG
ummmmmmmm I Don't think it will be a big improvment from integrated graphics.
BGP is my favorite
Discussion Starter #4
Well on the back (lol) it shows like a big difference from Integrated soo idk
i just want a better gfx card but i good cheap one
Get this. It's probably at least four times faster for the same price, and supports pixel shader 2.0 and directX9. That MX will only support directX 7.
OG
Try to get a 5500 or 5900 from best buy if you want some improvements. They shouldn't be much more than the mx440 costs.
BGP is my favorite
Discussion Starter #10
ok thanks ill tell my dad soo he can use his credit card
edit:forgot i need PCI
and at best buy the PCI 5500 is $102
OG
Ah forget what I said get the one fishie told you about thats a good one for a great price
BTW I have that radeon 9550 in my moms comp and it plays CS:S at 1280X1024, medium, 2Xaa with 40-80 FPS.
So you can expect to get that with it too since her comp has a 1.7Ghz xenon.
that card at best buy is pci, you need to make sure you get one that is compatible with your motherboard which i think is agp. anyway make sure and get a 9600 series from newegg if it is agp slot. gl.
BGP is my favorite
Discussion Starter #15
ok umm i need PCI i dont even have any AGP slots and im looking for others too soo... when i find more ill post um
Originally Posted by BluSmurf
ok umm i need PCI and im looking for others too soo... when i find more ill post um
Wait... you don't have AGP? You're best off not buying a graphics card then because PCI doesn't really work well at all for video cards.
BGP is my favorite
Discussion Starter #17
ok...
damn like a month ago i member a geforce 5500 for $50 and now it went back up to $100
ok...
Well it's not the end of the world. Just save up a few more months, get a new motherboard, 512 stick of ram, and that video card and you will have one hot gaming machine!
BGP is my favorite
Discussion Starter #20
wait i just got off the phone with my friend and he has a HP pavilon and he has i think a Geforce 5500 or 6200 and it works fine and hes got 128mb of ram and a crappy motherboard
how do i check how much ram i got? i i think i got more than 256
1 - 20 of 35 Posts
