1 - 6 of 6 Posts
I have been here for quite some time, and yet i still don't know what to do about memory timings..<br><br>
Heres a pic..It should tell you everything you need to know. Right now im running the memory 267 @ stock voltage...and its definitely not stable, yet it boots. Someone please tell me what i need to do/change to avoid the error count in mem test.<br><br>
Thanks In Advance<br><a href="http://assets.overclock.net.s3.amazonaws.com/3/37/376da7a0_vbattach34038.jpeg"><img alt="LL" src="http://cdn.overclock.net/3/37/525x525px-LL-376da7a0_vbattach34038.jpeg" style="width:525px;height:394px;"></a>
I've googled looking to what chip they and haven't really found anything concrete, I've seen people pointing to hynix, winbound, and samsung<br />
<br />
What are your current timings and what are the stock volts?
<tr>
<div>
Originally Posted by <strong>boredom</strong>
</div>
<div style="font-style:italic">What are your current timings and what are the stock volts?</div>
</td>
</tr>
</table>
</div>Here's a SS of Cpu-Z for the timings..<br />
<br />
As for the voltage. Im not sure. I believe it's set to "AUTO".<br><a href="http://assets.overclock.net.s3.amazonaws.com/0/0a/0a8361ab_vbattach34041.jpeg"><img src="http://www.overclock.net/image/id/616420/width/525/height/525/flags/LL"></a>
It's either Hynix based or TCCD(5), those would be my guesses<br />
<br />
A good way to find out if it's TCCD is to have the RAM run at 200mhz and see if it can boot at 2-2-2-X with 2.5v-2.8v
Discussion Starter #5
<tr>
<div>
</div>
<div style="font-style:italic">It's either Hynix based or TCCD(5), those would be my guesses<br />
<br />
A good way to find out if it's TCCD is to have the RAM run at 200mhz and see if it can boot at 2-2-2-X with 2.5v-2.8v</div>
</td>
</tr>
</table>
</div><br />
I Shall try that!. SO put everything back to stock and see if the ram can boot at 2-2-2-? ..explaing these numbers..Are they in the same order in the bios or??
Yup, remeber to try it at 2.6v and work your way up until 2.8v, if none of them work then it's probably Hynix based<br />
<br />
The first 2 is the cas, the second 2 is the trcd, third 2 the tras, and the final 2 is the trp<br />
<br />
They may or may not be in the same order
1 - 6 of 6 Posts
