General question concerning memory i'm going to buy
215 3
I'm buying this new motherboard and it says the highest memory it supports is DDR3 1333Mhz. The memory i'm looking to buy is DDR3 1600Mhz. Now does this mean that my motherboard wont support the 1600Mhz period or will it just limit the speed to 1333Mhz? I heard that it limits the speed but i just want to be 100% sure before i buy this RAM. Thanks in advance
1 - 4 of 4 Posts
OG AMD
Just means 1333MHz is the "stock" speed,1600 will be available,but you will have to "overclock" or change the settings in bios.
The RAM is usually limited by the CPU by the way,not the motherboard.
1 - 4 of 4 Posts
