Gentle Typhoon AP-29 & AP-31 Review
7555 Views 27 Replies 25 Participants Last post by  ehume
I don't know if this is a repost, I did a few searches on here and got nothing but I found fan tests on youtube by Cooling Technique.
The actual review of them coolingtechnique.com
Now we have actual results. Enjoy
1 - 20 of 28 Posts
AP-29 test
AP-31 test
holy crap 31 sounds like an engine taking off
Thank you for flying with Scythe Airlines, we hope you enjoy your stay in OMFGWHONEEDSTHESEFANS.
Don't stick your fingers in
A buddy of mine has 3 of the 5400's in his case. I make him unplug them when he brings his rig over. It's absurd.
Not-So-Gentle-Typhoons.
These arent Gentle Typhoons, these should be called Typhoon AP-whatever
Like Ehume said awhile back, the GT AP14 is quiet at its max, and GT AP15 noise level is a bit noticeable at max.
Mine San Aces dont even run above 1500rpm.
Hahaha
Wonder if you can stop them with your tongue.
Try to mate with it, i dare you
Wowzers!. Ill take 10...
Well that will make all the men here cringe, it would make a good shock video
The static pressure is really high, this thing is crazy.
*JIZZ*
I want that 5400 xD I'd replace all my 38mm fans with them >,>
Anyone know if the rheobus extreme would handle these?
NVM It seems for case fans these still lose to the UK 3K fans Though would love to have this on a tower heatsink
@Darkapoc
your fan controller can handle 30W per channel right?
If it is then it can, the power out put is 13.8W at full speed
That 5400 is insane. And I thought my 4200 Gentle Typhoon was loud..... I have 3 of the 3000 rpm ones and they arent too bad noise wise.
Indeed, had one up my Ultra Kaze 2000 once, robbed me of my skin. Can't imagine what this would do.
well Considering AP 15 is scarce the least i can see.
this and a controler is the way to go, maybe AP 30?
Good bearings right there. Spin for at least 10 seconds.
1 - 20 of 28 Posts
