Get 3Dmar06 running in Vista x64
436 Views 3 Replies 4 Participants Last post by  G|F.E.A.D|Killa
I don't know about you guys but I had a hard time getting 3dmark06 to run in vista x64. If you get an error saying "openal32.dll was not found in the registry"
then you need to go here
http://connect.creativelabs.com/open.../AllItems.aspx
and download and install "oalinst".
You guys probably already know this but I had to use my mad Google skills to figure it out.
Reactions: 2
1 - 4 of 4 Posts
You can do that or I have found that just uninstalling 3dMark AND Open AL from control panel, restarting, and reinstalling work great.
EDIT: 1000 posts, woo!!
I have never had a single problem with 06 and vista just reinstall opengl and your good
1 - 4 of 4 Posts
