1 - 5 of 5 Posts
Can I just Install windows straight to it? or will I have to change setting? Its only a 64gb SSD So I will put my OS and soem games on it.
after I get my os on the SSD will I have to wipe my entire other drive I am using as a primary right now? or can I just leave/delete windows off it?
Thanks in advance!
Make sure the sata configuration is set to ahci not ide. I would then save any old oimportant files on the HDD you are replacing then format it because windows bootmanager will go haywire if it detecs an OS on both drives. I would do a clean install on the ssd and check the manufactures website for any new firmware to improve speed/stability. Then I would plug the old drive in and you should be set!
Storage Nut
1 - 5 of 5 Posts
