Why hello there,
Back story:
I used to have a custom loop setup about a year ago, it was a Triple and single radiator cooling only the CPU with plans for cooling my cards in the future, but then my reservoir cracked (Did a dumb a tightened it too much) which I soon replaced and after that my pump died! so I took it all out sold my CPU block and that was that. BUT NOW I CRAVE THAT WATER COOLING ONCE MORE.
Parts I have:
Single radiator
Triple radiator
Reservoir
4 13/10mm (10x1.5mm) Compression fittings (On the two radiators)
2 3/10mm (10x1.5mm) Compression Fitting 45° (On the reservoir)
Coolant
Parts I need:
CPU block. Intel socket LGA1155
Pump
Questions I have:
Should I use both the single radiator and the triple again or should I just use the triple radiator? what do you guys think?
Am I using the fitting G1/4?
What I must stress:
I'm truly a pauper and do not have much money so this needs to be on the cheap side, I'm not looking for crazy cool temps just temps similar to my ARCTIC Freezer 13. This is mainly so I don't need t use a CPU fan.
Thanks!
Back story:
Parts I have:
Single radiator
Triple radiator
Reservoir
Coolant
Parts I need:
Pump
Questions I have:
What I must stress:
Thanks!
