Hey guys i recently picked up a Asus p5nt deluxe/780i main board and a E8400 and im trying to get it to 4ghz while keeping it stable.
what i have done so far..
unlinked the cpu/ram clocks and put the ram to 800mhz for testing sake. its corsair dominator 1066 stuff.
Upped the Fsb to 445x4 to bring cpu clock to 4ghz.
At these settings it boots fine and seems fine i ran prime 95 to see how it goes and got some errors.
[Thu Oct 30 14:42:15 2008]
FATAL ERROR: Final result was 79EA3773, expected: 3247CE82.
Hardware failure detected, consult stress.txt file.
[Thu Oct 30 15:22:46 2008]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
I havnt changed the voltages on the Cpu or the Mobo at all yet, if i do this will it make it a bit more stable? the temps are fine under load im getting about 46/47'c idle is 38/39'c. Or do i need to clock the ram up higher? i cant see this changing the stability on the cpu tho..?
Thank you in advance
Kerelm.
Kerelm.
