getting new cooling
718 17
im getting the thermaltake bigwater SE is there a way to get a vga block and cool with the water cuz it only got one cpu block and one tube to it so i need kind of a splitter for the water
1 - 18 of 18 Posts
I'm installing a BigWater SE, and a Thermaltake Aquarius waterblock--I got both from ZipZoomFly.
You won't need a splitter, unless you want to go that route. I'm plumbing mine in series.
Hey BloodElf, which model gpu waterblock do you have? I have the Aquarius 2, if I recall correctly, copper with a clear top.
Originally Posted by dani
i need gpu block
i looked alot for parts can someone help me find them for cheap max. 120$
Do you have a spare 5.25" drive bay? If so, you might like the newer Bigwater SE It has a bay reservoir, *and* you can put the pump in the bay too, which makes for a compact install. It's $115 at ZipZoomFly:
http://www.zipzoomfly.com/jsp/Produc...uctCode=371237
It doesn't have a GPU waterblock, but you could add one later. You might have to do that regardless, given your price constraint.
Hope this helps.
SNERP!!!
$120 WC kit with a GPU block is just about impossible if you are buying everything.
SNERP!!!
:withstupi
Sorry about the crappy post. I meant a custom setup. Yes you can get a kit for that price. Just don't expect to overclock a ton with a kit. They are great for stock speeds, mild overclocking and they are quiet.
Discussion Starter · #17 ·
and wats the problem about the kit i showed the kingwin one ????
pump,block,radiator watertank???
cuz buying parts is more expensive i wont do ton of over clocking maybe from 3.0 to 3.6 or to 4.0
1 - 18 of 18 Posts
