Getting Ready to Buy/Build First Rig
324 Views 6 Replies 6 Participants Last post by  happyxix
Thanks to all who gave me feedback earlier, I'm getting ready to buy all the parts and put it together. Here's the final list, coming in at just over $2k.
https://secure.newegg.com/WishList/M...spx?ID=6373849
I had a couple questions before I blow 2 g's, if anyone can field them:
1) The main reason I want this is to run a game a bit smoother. I slapped a graphics card in an ancient PC of mine a few years back to get Doom III to run and it has been doing an adequate job until I tried to run some recent demos/games on it. I wanted to build a PC both for the fun of it and to run Empires: Total War smoothly on all the highest settings. That being said, I think I may be overestimating all the hardware I need to do this. Am I trying to kill a fly with a cannon, and if so, how much should I spend/what should I buy to get a PC with enough muscle to run the Empires game and keep up with the times for the next few years?
2) I had a few comments to get the ASUS motherboard over the EVGA one, and since they both are the same price and the EVGA has higher reviews on average, think I will stick with the EVGA. Anyone have any reasons to not get it, other than personal brand-preference?
3) I'm not really wedded to the video card, I just picked the 4850x2 over the 4870. Any thoughts on the better card?
Thanks again, I appreciate the input!
1 - 7 of 7 Posts
Thanks for pointing it out.
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #:WD1001FALS
Item #:N82E16822136284
Return Policy:30 Day Return Policy
In Stock
Note (Add)
$119.99 $119.99
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
Model #:BX80601920
Item #:N82E16819115202
Return Policy
rocessors (CPUs) Return Policy
In Stock
Note (Add)
$288.99 $288.99
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler - Retail
Model #:RR-UV8-XBU1-GP
Item #:N82E16835103055
Return Policy:Standard Return Policy
In Stock
Note (Add)
$69.99 $69.99
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D - Retail
Model #:TR3X6G1600C8D
Item #:N82E16820145224
Return Policy:Limited Non-Refundable 30-Day Return Policy
In Stock
Note (Add)
$199.99-$16.00 Instant$183.99
CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Compatible with Core i7 Power Supply - Retail
Model #:CMPSU-1000HX
Item #:N82E16817139007
In Stock
Mail in Rebate
Note (Add)
$299.99-$40.00 Instant$259.99
SAMSUNG 22X DVD±R DVD Burner with LightScribe Black SATA Model SH-S223Q - OEM
Model #:SH-S223Q
Item #:N82E16827151173
In Stock
Note (Add)
$24.99 $24.99
Arctic Silver 5 Thermal Compound - OEM
Model #:AS5-3.5G
Item #:N82E16835100007
Return Policy:Consumable Items Return Policy
In Stock
Note (Add)
$6.99 $6.99
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Model #:132-BL-E758-A1
Item #:N82E16813188039
In Stock
Note (Add)
$299.99 $299.99
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail
Model #:Twelve Hundred
Item #:N82E16811129043
In Stock
Note (Add)
$214.99-$35.00 Instant$179.99
SAPPHIRE 100270SR Radeon HD 4850 X2 2GB 512-bit (256-bit x 2) GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Model #:100270SR
Item #:N82E16814102809
In Stock
Note (Add)
$309.99-$20.00 Instant$289.99
Antec 761345-75024-0 120mm Blue LED Case Fan - Retail
Model #:761345-75024-0
Item #:N82E16835209011
In Stock
Note (Add)
$19.99 $39.98
Acer P243WAid Black-Silver 24" 2ms(GTG) HDMI Widescreen LCD Monitor with HDCP Support - Retail
Model #:ET.FP3WP.001
Item #:N82E16824009125
Return Policy:LCD Limited Non-Refundable 30-Day Return Policy
In Stock
Looks good. The 4850x2 is a 220w GPU so you don't need a 1000w psu. The Corsair 750tx should be fine with headroom.
Agreed, looks good considering you're on machine that runs doom 3 "good enough. I doubt you will be disappointed
i might get an nvidia gpu with the evga mobo, or get a gigabyte ud5 or extreme with that 4850x2
I would take down prices somewhere and soop up the GPU. 260GTX is good but at that res you can use something slighty better especially when everything else is top of the line.
Main things I see that can switched off is the Mobo, Heatsink, Ram and probably the PSU.
I know there are good 1366 mobos at around the $200 area and not the $300. The v8 could be changed to a vendetta2 or dark knight, there are some good OCZ an G.skill rams that are much cheaper than the always overpriced corsairs. And also coolermaster have a 750W psu for only $50 something refurbished and I can vouch they are as good as new. Or 850W for 80 I think.
Use all that money saved and upgrade that GPU! Or get 2 in sli. Sad to see such a expensive system with only a medium grade video card.
1 - 7 of 7 Posts
