1 - 18 of 18 Posts
Since I want to make a waterblock, but dont have any basic materials, I have come up with an idea.<br><br>
Would it be possible to use one of these:<br><a href="http://www.jaycar.com.au/productView.asp?ID=HB5060&CATID=5&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=481" target="_blank">http://www.jaycar.com.au/productView...=&SUBCATID=481</a><br><br>
; add some barbs, seal it and use it as a waterblock?
Not really original, but still a kickass idea.
<div>Originally Posted by <strong>Intel-legent</strong></div>
<div style="font-style:italic;">Since i want to make a waterblock, but dont have any basic materials, i have come up with an idea.<br><br>
; add some barbs, seal it and use it as a waterblock?</div>
</td>
</tr></table></div>
Man I dont know..<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">...I saw where a guy used a jelly jar once, if I can find it I'll link you to it...<b>EDIT:</b> I couldn't find it,whatever you use leak test the fire out of it before you get it near your rig..<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Hmmm aluminum good conductivity, but I would go for copper personally.
great idea bud, go for it, you may be onto something here. Yes Cu is better than aluminum, but hey, aluminum may do a good enough job.
Go with copper, it can be soldered. Sealing aluminum will be a total challenge unless you can Mig/Tig weld.<br><br>
Just silver solder a copper end cap to a 2x2" square of 1/8" plate and add 2 barbs at the top. Not the best but it works.
Discussion Starter #7
The problem is i cant find a place near my palce which sells copper....<br />
<br />
Thats why i came up with the alubox idea..<br />
<br />
An di was plannign to permantly seal the box ie with glue or sumthing like that
Packet Pusher
Most glues do not stand up too long to coolants. They break down after a bit and leak.
Look here....<a href="http://www.onlinemetals.com/" target="_blank">OnlineMetals.com - Small Quantities Specialist - Online Metal Cutting and Online Metal Ordering</a>
Thats a start... get that little box, and cut on side of it out, then take an old vga cooler, like one off a 6600/6800 series card and cut it to size so it fits in to replace th one side, and on opposite side put your barbs... seal it all and boom, you have a wied, ugly, but half decent block!<br />
<br />
To seal it all, i say solder/braze it.
<tr>
<div>
Originally Posted by <strong>ira-k</strong>
</div>
<div style="font-style:italic">Look here....<a href="http://www.onlinemetals.com/" target="_blank">OnlineMetals.com - Small Quantities Specialist - Online Metal Cutting and Online Metal Ordering</a></div>
</td>
</tr>
</table>
</div>I only live 100 miles from Onlinemetals and the S&H is usually 1/5th of total, so shipping to down under would slay him.
<tr>
<div>
Originally Posted by <strong>Dryadsoul</strong>
</div>
<div style="font-style:italic">I only live 100 miles from Onlinemetals and the S&H is usually 1/5th of total, so shipping to down under would slay him.</div>
</td>
</tr>
</table>
</div> Wow, I guess it would!! Hadn't noticed he was an Aussie....
<tr>
<div>
</div>
<div style="font-style:italic">The problem is i cant find a place near my palce which sells copper....</div>
</td>
</tr>
</table>
</div>You don't have a local plumbing supply store?
Discussion Starter #14
Our local plumbing stores only have steel endcaps :S
Maybe I could hook you up with a copper care package next month.<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Discussion Starter #16
Whats a copper care package??<br />
<br />
anyways....<br />
<br />
I had another idea, since i have a lot of thin alu bars, it thought i can somehow stack them up and use it like an ordinary block.<br />
<br />
Any thoughts?<br />
<br />
PS i hope this orignal enough <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" /><br><a href="http://assets.overclock.net.s3.amazonaws.com/2/2a/2a97d4a7_vbattach34031.bmp"><img src="http://www.overclock.net/image/id/616429/width/525/height/525/flags/LL"></a>
You could seal those ally bars with red permatex to make it leak proof, and the design looks quite good.<br />
<br />
Copper care package = package of copper parts.
Hey I found the jam jar cooler, he has several other things of that nature also...<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />......<a href="http://www.spodesabode.com/content/article/jamjar" target="_blank">Spode's Abode - Jam Jar Watercooling (Part 1)</a>
1 - 18 of 18 Posts
