when i get home ill help you but if you read the manual it should say something like voltage under MIT then turn that voltage to manual then you will see cpu voltage pop up all the way at the bottom it should say normal 1.35 or something then you can add +0.025 and so on and so on... you will have to do a little math to figure out the right voltage... Good luck
that's the cpu-NB voltage, I'm looking for the HT voltage. If they are the same thing, then the Phenom II thread needs to be changed
HT i have 2050MHz, bit last days i know, its bug F3F bios, not possible changing NB multiplier, than must clr CMOS :-/...last is 11x possible. I tried about FSB and the same, only CLR CMOS (i tried CPU NB voltage, NB voltage...nothing, not post)
but now know, its BIOS problem version F3F, F2A i heard from friend with ours x4 940 is OK. If the instaled F3F, had the same problem...But x4 955 is support only in this F3F bios.:swearing:
Overclock.net
