I've seen this in a lot of threads. Suggestions have been:
- try disabling ATI Overdrive (tried, didn't help)
- try creating CCC Profile (example was in CCC10.5, but I have 11.2 and it has no options menu)
- use MSI Afterburner (tried, didn't help, although I didn't set any custom values in it).
So here I am, same problem and none of the aforementioned solutions works. I have read in various forums that it's to do with 2D clocks and 3D clocks and maybe even voltages. I don't know what to set them to, how to set them or where. I imagine MSI Afterburner lets me do it. The 11.2 CCC isn't very helpful.
What I'm seeing is that if I do something like scroll a browser window or move a window around the screen or resize it on the main monitor, the second monitor will flicker. If I leave everything alone (no mouse, no keyboard, just sit back) then the second monitor almost doesn't flicker at all.
I have found one workaround that limits the flicker quite a lot, but it's one I'd rather not have to do. If I change the second monitor from 32 bit color to 16 bit color, the flicker is gone. Watching video on it (which I do *very* often) it looks pretty crappy. If I don't find a better solution, I'll go with that though.
Here's a screenshot of what CCC shows me right now (I have seen the GPU clock and Memory clock at the bottom jump up to much higher values, but then they settle back down to 157 / 300).
I don't do any 3D (unless Windows 7 Aero qualifies as 3D) if that helps. I've also never OC'ed the graphics card, I wouldn't know how to or why I'd want to. I'm not a gamer.
Config:
Monitor 1 = LG Flatron E2750 27" set at 1920x1080 connected via DVI.
Monitor 2 = Samsung Syncmaster 19" 913N set at 1280x1024 connected via VGA (with DVI-VGA adapter of course)
Config:
