2841 - 2842 of 2842 Posts
Hey Guys...
Can someone give me a short instuction how to remove the FAN assembly?
One of the FANs starting to shake (a bit) and to make sounds starting 70% load.
It's not hitting its surrounding (like it oftens does - mine also. Soveld this by bending LED holders a bit).
But now the FAN bearing is going to die.
Is it possible to remove the FAN assembly only without dismounting the whole card?
Hey Guys...
Hey; this is a video about taking it off a Gigabyte 1080 Extreme Edition. They use the same cooler pretty much.
Also if you need new fans here you go: 95mm GIGABYTE AORUS EXTRME GTX 1070 1080 Ti 11G Triple Fan 4Pin T129215BU R241 | eBay
And if you are trying to replace the fans; you have to suck it up and take it apart.
