Gigabyte EP45-UD3P dual nics
1341 Views 7 Replies 8 Participants Last post by  Sullivan
I have the dual nics on my board and wonder how everyone else is using them. Are you teaming or just using one. Is it possible to have one only talk to the net and the other to the local network? Or should I just hook both of them up and not team them?
1 - 8 of 8 Posts
no having 2 is useless. there is no need for 2. just one as a backup. all the myth about it helping isn't real
^true, but if you have 1 connected to the modem, and the other connected to another PC, then it's a hellofa lot better than USB connected to modem and single nic connected to other PC
I have four of those damn things on-board, of which three are completely useless
I've got the similar EP45-DS3R and I'm only using 1 of the Ethernet ports. Teaming is really only useful if you have a VERY fast connection to the machine(s) at the other end, otherwise it's a waste of electrons.
Most OSes will let you run a machine with 2 Enet I/Fs as a router. Ask someone else how to do it on Windows though, I've never used it.
they are useful if you want to offload your internet traffic from your local traffic,for example you have a gigabit LAN and a fast internet connection you can max out your internet connection without slowing down LAN transfers.
or if your hardware supports you can team them for increased bandwidth or redundancy.
also useful if you want to manage your systems, use LAN 1 for network traffic, and LAN 2 for console/rdp/vnc/etc
dual/multiple NICs are also nice to have if using that machine as a router/ids/proxy/gateway, hell my router has 6 network cards in it...
i myself have a team of 2 gbit nics in my fileserver, and two primary workstations as i normally have a lot of traffic between them... though, you will need hardware that supports this to take advantage of it...
if you are never going to use two, there is no need... However if you are, i guess that would justify a need... What is this myth about helping?
And if you guys find it annoying seeing the red network disconnected icons in the status bar by the clock, do what I did:
Open up the device manager, go down to the network part, disable all but the one you want, then you will only have one showing up.
1 - 8 of 8 Posts
