How do I stop this? every time I play music I get this pop, pop sounds and its really...really annoying!! :swearing: especially when I make and record music on it!
There may also be something wrong with some connections on the motherboard itself, make sure if you have any front audio ports, that the cords are fully connected to the motherboard, this may be a interfering issue.
I have my wires connected from the back, all the cords are fine. everything is connected good, I've read up something about the this board having this type of issue. I thought I may needed to update my mobo or something...maybe I should get a new sound card... because this popping is nuts! mainly its wav sounds, mp3 doesn't pop lol
I would do that, then pick up a cheap sound card from a local store to test, and if it fixes it, then theres the problem. If I were you, I would do that, and if that fails, RMA the board if you can.
Overclock.net
