GIGABYTE GA-Z77MX-D3H Micro ATX Intel Motherboard
Description:
Supports 3rd Gen. Intel 22nm CPUs and 2nd Gen. Intel Core CPUs (LGA1155 socket). GIGABYTE Digital Power Engine with GIGABYTE 3D Power. GIGABYTE 3D BIOS (Dual UEFI). PCI Express Gen 3.0 support. 2 way SLI and 2-way CrossFireX multi-GPU support. Lucid Virtu Universal MVP GPU virtualization support. HDMI, DVI, RGB. High quality 108dB SNR HD audio. GIGABYTE 333 Onboard Acceleration (USB 3.0, SATA 3.0 & 3x USB Power). GIGABYTE On/Off Charge for USB devices
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Gigabyte |
EAN | 0818313014405 |
Feature | CPU: Support for Intel Core i7/i5/i3/Pentium/Celeron processors in the LGA1155 package. Chipset: Intel Z77 Express Chipset Memory: 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory. Dual channel memory architecture. Support for DDR3 1600/1333/1066 MHz memory modules. Support for non-ECC memory modules. Support for Extreme Memory Profile (XMP) memory modules Audio: VIA VT2021 codec. LAN: Atheros GbE LAN chip (10/100/1000 Mbit). Support for 2-Way AMD CrossFireX/NVIDIA SLI technology. Expansion Slots: 1 x PCI Express x16 slot, running at x16. 1 x PCI Express x16 slot, running at x8. 1 x PCI Express x16 slot, running at x4. 1 x PCI Express x1 slots. Storage Interface: 2 x SATA 6Gb/s connectors. 4 x SATA 3Gb/s connectors. Support for RAID 0/1/5/10. Back Panel Connectors: 1 x PS/2 keyboard/mouse port/1 x D-Sub port/1 x DVI-D port/1 x HDMI port/2 x USB 3.0/2.0 ports/6 x USB 2.0/1.1 ports/1 x RJ-45 port/1 x optical S/PDIF Out connector/5 x audio jacks Internal I/O Connectors: 1 x 24-pin ATX main power connector; 1 x 4-pin ATX 12V power connector; 2 x SATA 6Gb/s connectors; 4 x SATA 3Gb/s connectors; 1 x CPU fan header; 2 x system fan headers; 1 x front panel header; 1 x front panel audio header; 1 x S/PDIF Out header; 1 x USB 3.0/2.0 header; 3 x USB 2.0/1.1 headers; 1 x serial port header; 1 x parallel port; 1 x Trusted Platform Module (TPM) header; 1 x Clear CMOS jumper USB: Up to 4 USB 3.0/2.0 ports. Up to 10 USB 2.0/1.1 ports. |
Label | Gigabyte |
Manufacturer | Gigabyte |
Model | GA-Z77MX-D3H |
MPN | GA-Z77MX-D3H |
Publisher | Gigabyte |
Studio | Gigabyte |
Title | Gigabyte Intel Z77 LGA1155 AMD CrossFireX/NVIDIA SLI DVI/HDMI Dual UEFI BIOS mATX Motherboard GA-Z77MX-D3H |
UPC | 818313014405 |
CatalogNumberList - CatalogNumberListElement | GA-Z77MX-D3H |
Item Height | 3 inches |
Item Length | 11 inches |
Item Width | 11 inches |
Package Height | 2.7 inches |
Package Length | 10.6 inches |
Package Weight | 6.15 pounds |
Package Width | 10.6 inches |
PackageQuantity | 1 |
PartNumber | GA-Z77MX-D3H |
ProductGroup | Personal Computer |
ProductTypeName | MOTHERBOARD |
UPCList - UPCListElement | 818313014405 |
Item Weight | 2.8 pounds |
