1 - 20 of 1,506 Posts
Discussion starter · #1 ·
*** UPDATE ***
So far we can say this about boost clocks for the Gigabyte 570 OC;
Mine: adds 220 clock at any frequency
_jokes_: adds 220 clock at any frequency
Oridin: adds 170 clock at any frequency
rdmx: adds 170 clock at any frequency
My proof;
stock: 980 / 1201
437
_jokes_ proof:
+100: 1080 / 1301
375
Oridin / my proof;
Oridin: +138: 1118 / 1289
Me: +138: 1118 / 1340
416
rdmx proof; (can you verify rdmx?)
+180 1161(suspected) / 1331
429
So it seems that so far there are two lotteries when buying a GTX 670 OC;
* boost clock adds 220 or 170
* max clock varies
It's possible they're correlated but I'm leaning towards not after talking to Oridin. rdmx can pass a test at +180, but I don't think Oridin has.
Also, it seems like my core clock becomes more stable as I raise memory clock, to a point. Clocking core gives worst results when memory is left at zero OC, which is why I think _jokes_ settled at +120: 1100 / 1320 to benchmark games (his screenshots never raise mem clock).
If you're reading this buddy, try again with memory at +550
Perhaps there is some way of identifying whether or not it's a 220 boost or 170 boost by PCB stickers?
In any case, I'm dying to know, does a 120 boost clock exist? what about a 270 boost clock?
PS: I firgured out what's going on in that 1400 clock screenshot from _jokes_. I believe it's an error and he didn't clear GPU-z log after running a +200 test and crashing.
375
*** /UPDATE ***
I picked up one of these today for $525 AUD.
Someone said it might be useful to make a thread here.
If you have any questions, etc, I'm happy to answer. Here is what I've done so far;
http://3dmark.com/3dm11/3353787;jsessionid=1c5mdgwq1bws9cfb09i2khsuv
P9252 3DMarks
This is at out of the box settings. I have tried to OC further using gigabytes easyboost software, but any increase to core speed results in a revert back to 705 when I click apply. I think it's not updated for this model yet?
450
top: new gtx670
bottom: old 9800gtx
450
450
Try using EVGA's Precision. Should allow for easier overclocking. Also, please post a GPU-z validation so we can see what the stock clocks for your factory overclocked card are. Thanks!
Originally Posted by Martyr82 View Post
493
I'm confused. How does a GTX 670 with 1 SM disabled and stock clocks of 980/1059 Boost beat a reference GTX 680 (reference clocks=1006/1059) by 440 points in 3DMark11 GPU score? I just set my 680 to stock clocks and ran 3DMark11, and this is what I got:
Forget the P mark. The graphics score is 9600 which is just over or around what a stock 680 should be getting and what my 470's yield both at 700MHz.
Yeah, I'm just
And that's only a factory overclock.
Get this stuff while it's available is all I can say. Good god.
How?
Click the validation tab then submit validation on that tab.
Originally Posted by tx-jose View Post
i dont know what else you want?? he has pictures of the box, of it in his rig, and GPU-Z...
do u want him to mail it to you?
Just covering all the bases, that would be nice though!
Originally Posted by pengs View Post
Forget the P mark. The graphics score is 9500 which is just over or around what a stock 680 should be getting and what my 470's yield both at 700MHz.
Yeah, I'm just
My 680 only gets 9150 ish graphics score @ stock clocks.
The clocks on the Gigabyte OC 670 are 980/1059 boost while the reference Nvidia clocks for a 680 are 1006/1059.
So why is the 670 outscoring a 680 by 400+ points in the 3DMark11 GPU score?
I know nothing about 3d mark, but it says your cpu clock is at 1.6ghz. Your physx score is far higher than his, could that 1.6 be the reason your gpu score is lower?
he probably has power saving enabled on the processor which makes it down clock to 1600Mhz when not in use (when 3dmark takes its info most likely)
