1 - 20 of 20 Posts
I was playing Battlefield 4 for a while tonight. To keep an eye on the temperatures of both cards, I had GPU-Z running. I kept a log file but it looks like just one of the card's stats was recorded. Anyway, my real question is in a game like that, what kind of temps should I expect for those cards?
I know the primary card will be higher than the other. I did notice that the temperature of that card reached a max of 79C.
Is that common?
Seems a tad high. See my rig in sig, Temps normally in the low to upper 60s, and the fans, on the normal profile, barely spin up. And yes, the top card runs 2-5 deg hotter than the lower card. Got good case airflow? I'm not familiar with the 540 case.
EDIT: looked at case. You'll have positive case pressure with the stock fans. IMHO, and others will argue, and based on my experience, negative case pressure works best for gamers and overclockers. Are the H420x fans intake or exhaust?
It was difficult for me to switch between the game and keeping tabs on GPU-Z....damn program kept on closing out on me but I figured out how to keep it on top of everything.
I'll run through it again and see what happens. Maybe increase the fan speed of the case fans one of which blows directly over the cards.
I might've also read that temperature wrong.
I don't quite understand GPU-Z's temp logs yet
You can use HWMonitor to log temps, has a simple, even for me
, interface.
Discussion Starter · #9 ·
a second playing of Battlefield did show the temp of the primary card as high as 75C
The temp log it records doesn't show any number higher than 70C. ***??
EDIT....
I have a Corsair 540 case, those two Gigabyte 980 G1's, and an Asus Rampage Extreme V mobo.
Now I'm seeing that it got as high as 80C but that was during some intense fighting.
I'm hoping that I'm not abnormally high.
Damn....I got a lot to learn
He's fine, he's running a demanding resolution, 4k, not 1080p, and gpu's have to work harder to maintain frames and are probably constantly pegged 99% thus more heat heat. With my 2 x 660's my top card would get to 85C in more demanding titles, and that wasn't even at Ultra, mix of medium/high.
I did see a review on GTX 980 SLI during Battlefield 4 and the temps did max out at 83c.
I think I'm golden
Opinions?
it's high but not abnormal. Is your room temperature 20-25C or higher? If it's still winter for you, could be a problem during the summer.
If gpu(s) get into the 90's then you can start scratching your head, that something may be wrong.
There's always water if heat bothers you.
Discussion Starter · #14 ·
I may have been reading GPU-Z's readings wrong.....
Before I was looking at each card's highest reading and it was always at 80c
I just checked off "show current temperature" and it never went higher than 76c
and that matched up perfectly with the temperature reading of Gigabyte's OC Guru temp readings.
A rough estimate on my computer room temp puts it at around 19-20C
Also I did some Heaven benchmarking and the highest temperature on the primary card was around 74-76c
Always flyin' to high...
Temps seem normal.
In SOM and FC4 I get temps like that as well (75-80*) playing at 1600p and maxed out with my 970's so would think the 980's would be about the same. More so when my room is warm. Making a fan profile might bring it down a little but will make it louder too...
Discussion Starter · #18 ·
Originally Posted by IcarusLSC View Post
Temps seem normal.
If I did my fan profile right, I was able to drop the primary GPUs temperature during Battlefield 4 10 deg C!
Noisy though but I won't hear it with my headphones in
Also, how difficult is it to remove the Windforce coolers and reapply better thermal paste?
A couple screws on the backplate, 4 on the cooler and it comes off the 970s. Watch the led plugs.
I changed mine fwiw but it made no difference, tried both Noctua and AC Ceramique.
Discussion Starter · #20 ·
I've heard that people would take off the coolers and find that the paste was poorly applied.That's what got me thinking.
But if I can consistently drop the load temps 5 degrees through a different fan profile, then I'd be happy. I'll put up with some of the racket.
1 - 20 of 20 Posts
