601 - 620 of 7925 Posts
Guys, could you test your OC'ed cards with this demo? <a href="http://www.pouet.net/prod.php?which=61883" target="_blank">http://www.pouet.net/prod.php?which=61883</a> Because my card is stable in firestrike but not in Apocalypse When demo.
Maximum_Unleashed
Discussion Starter #602
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/590#post_24021766" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>TK421</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/590#post_24021766"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
anyone?</div>
</div>
<br>
I forgot to respond to this one, give me a few and I will check it out <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif"><br><br>
Ok looking at it now, it is very different. Is your goal to disable boost? I do see some areas where I would make some changes, for example the min voltage being the same as max isn't necessary on other than CLK 74. If a throttle condition occurs, you can expect a huge drop in clocks. The 4th voltage line from the top is not where I've seen anyone use max voltage. I have a 970 BIOS posted on the OP. You can copy over all the settings from that BIOS if you'd like to try that unless you are looking to disable boost.
Maximum_Unleashed
Discussion Starter #603
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24021842" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>leakydog</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24021842"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Guys, could you test your OC'ed cards with this demo? <a href="http://www.pouet.net/prod.php?which=61883" target="_blank">http://www.pouet.net/prod.php?which=61883</a> Because my card is stable in firestrike but not in Apocalypse When demo.</div>
</div>
<br>
Will try it and see how it goes <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">'<br><br>
Ok, <b><i><span style="text-decoration:underline;"><span style="color:#FF0000;">I got a TDR when running that</span></span></i></b>..<br><br>
I can tell you that my config is rock solid stable. I can pass loops of 4K Firestrike Ultra without blinking an eye. This demo, I tested at only 1080P +0mV / +0 memory (not even overclocking beyond BIOS defaults) so with all due respect, I am sorry to say <b><i><span style="color:#FF0000;">that demo is NOT STABLE code</span></i></b>. What you had to do was actually underclock your GPU to get that test to run, which is using a hardware tweak to compensate for faulty code. The graphics weren't even that good and the programmer may be using some unsupported "tricks".<br><br>
What a blast from the past though, I remember the very first demos back in the BBS days... wow...<br><br>
The good news is that you can test with Firestrike, Unigine Heaven, or something else KNOWN/PROVEN to be stable, factor recent driver glitches, and re-test your max overclock. I suspect you'll get closer to 1600 than 1500 with that ASIC <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022173" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022173"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Ok looking at it now, it is very different. Is your goal to disable boost? I do see some areas where I would make some changes, for example the min voltage being the same as max isn't necessary on other than CLK 74. If a throttle condition occurs, you can expect a huge drop in clocks. The 4th voltage line from the top is not where I've seen anyone use max voltage. I have a 970 BIOS posted on the OP. You can copy over all the settings from that BIOS if you'd like to try that unless you are looking to disable boost.</div>
</div>
<br>
Yeah, I'm looking to disable boost and raise the voltage as high as possible. (afaik 970G1 this can also go to 1.31v but software reads 1.275 and is limited to 1.31 by hardware)<br><br>
So you recommend matching the setting of my modded bios with the one you posted in the op?<br><br>
Also, I'm looking to keep the voltage constant as long as the card is in p0 state (3d)<br><br><br>
Thanks in advance for the recommendations.<br><br>
edit: I set the power limit to ridiculously high amount so that I won't hit any tdp limit whatsoever, I know under the worst conditions the card won't really consume 350w but it's just a peace of mind
Maximum_Unleashed
Discussion Starter #605
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022259" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>TK421</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022259"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Yeah, I'm looking to disable boost and raise the voltage as high as possible.<br><br>
edit: I set the power limit to ridiculously high amount so that I won't hit any tdp limit whatsoever, I know under the worst conditions the card won't really consume 350w but it's just a peace of mind</div>
</div>
<br><br>
Ok I see, if you are looking to disable boost we should ask DeathAngel74, Perhaps we can get a gigabyte BIOS version with BOOST disabled as a reference, I have had someone else recently ask for this.<br><br>
As far as copying the BIOS values, they won't result in disabling boost as you'd like but it would get you the other tweaks that have been tested to work well. You could then disable boost after you copy them over so you know you are working with tested values. <b><i><span style="color:#008B00;"><span style="font-size:16px;">You can also use K-Boost from EVGA PrecisionX</span></span></i></b> (and yes you can get it to work in MSI Afterburner also) to force your card to run at boost speeds despite GPU load without having to do this in the BIOS. Maxwell was really designed to boost and it works well with a tweaked BIOS <img alt="tongue.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/tongue.gif"> I know there are some games that just don't trigger BOOST because they don't push the GPU enough to make it boost.. I think that's the claim to fame with K Boost.<br><br><br>
PS. I got my 980's to consume around 385W <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022299" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022299"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
PS. I got my 980's to consume around 385W <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"></div>
</div>
<br>
I have 970, not 980. But I will increase to 450w JUST IN CASE <img alt="tongue.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/tongue.gif"><br><br><br>
I don't like to run any additional software, I'd really prefer if clockspeeds work similarly when we still have Fermi cards (no boost, full manual control over GPU speeds).<br><br><br><br>
What's the max voltage that the G1 can put out? Is it locked 1.31 like the majority of 970s out there?
Maximum_Unleashed
Discussion Starter #607
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022324" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>TK421</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022324"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
What's the max voltage that the G1 can put out? Is it locked 1.31 like the majority of 970s out there?</div>
</div>
<br>
I would caution using super high values, I think it could lead to some unwanted heat and instability. You can't draw that much power with 6+8Pin so no real benefit to configure it. We will round off. 6-pin, 100W. 8-pin 180W. Plus PCI-e (75W) = 355000.. If you want MAX value, there it is. I would still recommend the value posted in the BIOS though <img alt="wink.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wink.gif"><br><br>
G1 seems to be the same around 1.312v also.<br><br>
PS. If you are used to Fermi, just try the posted BIOS and see if you throttle. You'll probably be running at max boost all the time anyway <img alt="wink.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wink.gif">
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022339" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022339"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
G1 seems to be the same around 1.312v also.</div>
</div>
<br>
Hm, alright.<br><br>
So now we wait for deathangel to take a look at the G1 bios?
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022178" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022178"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
The good news is that you can test with Firestrike, Unigine Heaven, or something else KNOWN/PROVEN to be stable, factor recent driver glitches, and re-test your max overclock. I suspect you'll get closer to 1600 than 1500 with that ASIC <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"></div>
</div>
<br>
Great :) sorry, I don't know what "TDR" exactly means, but if it crashed after demo ended in case you didn't set "loop", then it's normal, but you say that your demo crashed in time when it's running, right? so you are probably right and I was using wrong benchmark whole the time :)
Maximum_Unleashed
Discussion Starter #610
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022483" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>leakydog</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/600#post_24022483"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Great :) sorry, I don't know what "TDR" exactly means, but if it crashed after demo ended in case you didn't set "loop", then it's normal, but you say that your demo crashed in time when it's running, right? so you are probably right and I was using wrong benchmark whole the time :)</div>
</div>
<br><img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif"><br><br>
"<b><i><span style="color:#0000FF;">Timeout Detection & Recovery (TDR)<br><br>
TDR stands for Timeout Detection and Recovery. This is a feature of the Windows operating system which detects response problems from a graphics card, and recovers to a functional desktop by resetting the card. If the operating system does not receive a response from a graphics card within a certain amount of time (default is 2 seconds), the operating system resets the graphics card.<br><br>
Before TDR existed, problems of this nature would have resulted in a system freeze and required a reboot of the operating system. If TDR is enabled and you see the TDR error message, "Display driver stopped responding and has recovered," this means that the Windows operating system reset the display driver.</span></i></b>"<br><br><br><a class="spoiler-link H-spoiler-toggle" href="#"><strong>M$</strong> <span class="spoiler-help">(Click to show)</span></a><div class="spoiler-hidden"><a href="https://msdn.microsoft.com/en-us/library/windows/hardware/ff570087(v=vs.85).aspx" target="_blank">https://msdn.microsoft.com/en-us/library/windows/hardware/ff570087(v=vs.85).aspx</a></div>
<br>
And I still need to reboot 98% of the time <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
Are you going to be working the same magic on the Gigabyte GeForce GTX 980 Ti G1?
Maximum_Unleashed
Discussion Starter #612
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24024320" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>scoobied77</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24024320"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Are you going to be working the same magic on the Gigabyte GeForce GTX 980 Ti G1?</div>
</div>
<br>
Yup <img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif"><br><br>
Looking for a willing tester <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24025325" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24025325"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Looking for a willing tester <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif"></div>
</div>
<br>
I'm thinking of selling my 980 and trading up to a 980Ti.<br><br>
Just hope there is a waterblock made for it.<br><br>
Although I waiting to see what AMD bring to the table as well. . .<br><br><img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
Maximum_Unleashed
Discussion Starter #614
EK has a partial block already and a FULL block "Coming soon"<br><br><img alt="tongue.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/tongue.gif">
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24026651" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24026651"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
EK has a partial block already and a FULL block "Coming soon"<br><br><img alt="tongue.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/tongue.gif"></div>
</div>
<br>
It would be the full EK block I want if I go down the Ti route. <img alt="wink.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wink.gif"><br><br>
Same as what's on my 980.
Maximum_Unleashed
Discussion Starter #616
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24027751" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>scoobied77</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24027751"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Same as what's on my 980.</div>
</div>
<br>
I was hoping the 980 blocks would be compatible but doesn't look like they are <img alt="mad.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/mad.gif">
Wonder if SKHYNIX vs HYNIX is of any difference? I search Gigabyte support and it indicates that my 980G1 has SKHYNIX memory (F10 Bios)<br>
Mine can oc SKHYNIX memory to 8000mhz no problem at all with the F10/F11 bios from Gigabyte (stock cooling)<br>
With Max Unleashed the same 8000mhz on memory, I tweaked a little bit for mine and I have lower core clock but about the same or a little bit higher boost clock compared to my tweaking with Gigabyte F10/F11 bios @@<br>
What do you think?
Maximum_Unleashed
Discussion Starter #618
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24029931" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>DirectDieWC</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24029931"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
What do you think?</div>
</div>
<br>
That makes sense, you shouldn't see any difference with memory O/C and your boost should be able to go higher using the custom BIOS.<br><br>
SKHYNIX vs HYNIX are the same company but not sure if they changed the memory modules after the merge. SK stands for South Korea.<br>
<a href="https://en.wikipedia.org/wiki/SK_Hynix" target="_blank">https://en.wikipedia.org/wiki/SK_Hynix</a>
Just for curiosities sake, if you take the stock 980 version of this card and flash this BIOS to it WITHOUT doing any extra over-clocking after the BIOS is applied can you still take advantage of the extra core and boost clocks that are set by default in this modded BIOS? <img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif">
<div class="quote-container" data-huddler-embed="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24030004" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Laithan</strong> <a href="/t/1544574/gigabyte-gtx-9xx-g1-gaming-h2o-air-bios-tweaking/610#post_24030004"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
<a href="https://en.wikipedia.org/wiki/SK_Hynix" target="_blank">https://en.wikipedia.org/wiki/SK_Hynix</a></div>
</div>
Appreciated your quick response <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"><br>
I'm still on stock cooling so I just push a little bit and test at my own risk :v btw, super stable custom bios. Thank you very much.<br>
My friend here has 980 ti G1 and it is pushing pretty high oc on stock cooling. Hope you will soon release a custom bios for it
