1 - 2 of 2 Posts
I got my p67a-ud4 today and I am confused on the manual, it says that for dual channel memory use slots 1,2 or 3,4 then to the right there is a chart showing for dual channel to use slot 1,3 or 2,4, so which is it, 1 and 3 or 1 and 2? thanks
yes its an error, you must have one of the first manuals.
You need to have it in slots 1 and 3 for dual channel, not 1 and two, there needs to be one slot in between.
1 - 2 of 2 Posts
