1 - 5 of 5 Posts
Just installed a Gigabyte 965P-DS3 and I can't find where to change the memory timings? Any help is appreciated, I've spent at least an hour looking for diy of some sort for this board... Thanx...
this wont help you but I'm thinking about buying that board for my first build...does it matter what kind of voltage your RAM needs or only the 1.8V works?
Thanks
Not sure, it takes my 667. Only problem now, is the constant shut downs and BS turn offs?!!!! Anyone else have problems like this. This board keeps turning off when I tweak the settings. I would actually rather take out the battery each time,. this program for the bios sucks donkey....
Its fairly simple . . . . while posting press DEL to get into the bios. When in the
bios press Ctrl + F1.
1 - 5 of 5 Posts
