1 - 20 of 612 Posts
Welcome to the Gigabyte X299 AORUS Gaming Seires Motherboard overclocking thread.
You are welcomed to post your questions and your solutions here related to the Gigabyte X299 Motherboards.
Click here to submit your overclock result
Click here to see submitted results
Click the links below to go to the page of:
Official Gigabyte X299 Motheboard page
X299 X299 UD4 Motheboard (rev. 1.0)
X299 AORUS Gaming 3 Motherboard (rev. 1.0)
X299 AORUS Gaming 7 Motherboard (rev. 1.0)
X299 AORUS Gaming 9 Motherboard (rev. 1.0)
X299 AORUS Ultra Gaming Motherboard (rev. 1.0)
Here is the information of the latest BIOS. You can also find it on Gigabyte Official X299 thread and support download page.
Official Latest BIOS:(Updated 8/23/17)
X299 AORUS Gaming 7: F7m
Change log:
1. Enhanced OC compatibility
2. Intel® VROC ready
3. Enhance i7-7800X DDR Overclocking
4. Improve XMP DDR compatibility
5. Improve TjMax offset option
Latest BETA BIOS:(Updated 8/8/17)
X299 AORUS Gaming 9: F6L
Change log:
Change Log:
Fixed MESH sleep bug
Latest BETA BIOS:(Updated 7/26/17)
X299 AORUS Gaming 3: F6I
X299 AORUS Gaming 7: F7I
X299 AORUS Gaming 9: F6I
Change log:
Fixed TB3 menu disappearing in BIOS
TJMax offset adjustments:
Max chip spec TJMax is 120C. This is the baseline.
GIGABYTE max TJMax is 105C. This is the ceiling.
Default TJMax is 95C.
TJMax offset formula is: 120 - TJMax offset = TJMax in Windows. Thus to set TJMax in windows to 100, set
TJMax offset to 20 (120-20=100).
If you set TJMax offset to less than 15 you will see a TJMax in windows for 105C.
BETA BIOS:(Updated 7/21/17)
X299 AORUS Gaming 3: F6H
X299 AORUS Gaming 7: F7e
X299 AORUS Gaming 9: F6H
BETA BIOS:(Updated 7/20/17)
X299 AORUS Gaming 3: F6F
X299 AORUS Gaming 9: F6F
X299 AORUS Ultra Gaming: F3C
BETA BIOS:(Updated 7/7/17)
X299 AORUS Gaming 3: F6D
X299 AORUS Gaming 7: F7A
X299 AORUS Gaming 9: F6E
X299 AORUS Ultra Gaming: F3A
Latest Production BIOS:(Updated 6/27/17)
X299 AORUS Gaming 3: F5
X299 AORUS Gaming 7: F6
X299 AORUS Gaming 9: F5
Older BETA BIOS:
X299 AORUS Gaming 3: F5J | F6A
X299 AORUS Gaming 7: F6H
X299 AORUS Gaming 9: F5K | F6A
X299 AORUS Ultra Gaming: F2A
For those looking for an easy breakdown of the PCIe lanes we just created a X299 configuration tool.
Click here to use the X299 PCIe Lanes Configuration Tool.
Posted by Matt
Discussion Starter · #2 ·
FAQ for latest BIOS updated 7/7/17
Q: What is "Enhanced Multi-Core Performance Mode"?
A: Intel Turbo Boost 3.0 picks two cores to run at 45x, the rest will run 40x. With EMCP all cores will be boosted to 45x.
Q: Isn't that the same as overclocking?
A: Yes and no. Typically when overclocking users have to sacrifice using P-states. This creates excess heat when idle. EMCP keeps all the power saving features but pushes Turbo 3.0 to all cores when under load.
Q: What about power modes, which should I use when testing?
A: Both balanced and high performance power modes will work with EMCP.
Recommended stress testing software:
Prime v26.6 for Non-AVX
Prime v28.x for AVX
Prime v29.x for AVX512
Many people here are using Prime 95 for testing. For a good load work, running your system with Prime95 v26.6 at 1344K is the first step. Using this setting can also let you get a good comparison to other people's testing results.
Discussion Starter · #6 ·
Originally Posted by hollowK View Post
Hi all,
Waiting for a x299 Gaming 9 MB and Silicon Lottery i9 7900x delid to arrive. Will share my results ASAP.
Oh. You got an i9-7900X pre-delidded processor from Silicon Lottery? You are so lucky bro. I ordered my 7900X online once it was available. I even didn't know there is someone selling pre-delidded CPU until I went to the V299 VRM disaster thread.
Currently there is no delid tool for LGA-2066 processor available in the market. For what I know so far, there are two confirmed delid tools for SkyLake-X and KabyLake-X LGA-2066 CPUs.
Delid Die Mate X(Click to watch the video of delidding a LGA-2066 processor)
Delid Master(Click to watch the video of delidding a LGA-2066 processor)
Delid Die Mate X may be the delid tool only for SkyLake-X and KabyLake-X LGA-2066 CPUs like 7740X and 7900X.
Delid Master, as what the video shows, is width adjustable, which means it can also be used for KabyLake and SkyLake like 6700K and 7700K.
Overclocker
Anyone know if there are any differences between the gaming 7 and 9? I know the 9 has the led thing on the rear i/o along with covers for the back of the board and m2 slots. Is there anything as far as performance is concerned that would make the 9 worth the extra $100? This will be getting paired with a binned SL 7900x when i can get one.
Both the gaming 7 and 9 have backlit I/O plates
Audio chips are different:
Gaming 9 : 127dB SNR AMP-UP Audio with High-End ESS SABRE 9018K2M DAC, LME 49720 and OPA1622 OP-AMP, WIMA audio capacitor
Gaming 7 : 121dB SNR AMP-UP Audio with ALC1220 & High-End ESS SABRE 9018 DAC with WIMA audio capacitor
and the 9 comes with an additional (digital?) RGB LED strip to place inside your case.
Also extra m.2 heat shields plus a pcie m.2 expand card with shield. And a backplate that appears to be for astetics only
Hardware Enthusiast
Just a heads up to anyone using these Gigabyte motherboards. The current BIOS at default settings does not properly apply the AVX and AVX512 offsets.
The current BIOS allows the processor to all-core turbo up to 4.0 GHz and single-core turbo up to 4.5 GHz. This is not to spec since 4.0 GHz all-core AVX512 on the 7900X will either phantom throttle or pull 300W. And 4.5 GHz AVX512 may be unstable.
So for my 7900X, the system (running all stock settings) would crash or BSOD on single-threaded AVX512 since the weaker of the two "preferred cores" is unstable @ 4.5 GHz on AVX512 with stock voltages.
Until Gigabyte fixes this, I recommend manually entering an AVX offset of 2 and an AVX512 offset of 4. (Though Silicon Lottery mentioned in an email to me that the stock offsets are supposed to be 3 and 5 respectively.)
Even if you never intend to run any AVX or AVX512, I suggest applying these offsets anyway since you never know when an application may actually use them.
Discussion Starter · #12 ·
These are only for 9 compared to 7:
1. M.2 to U.2 card;
2. PCIE card for additional M.2(four M.2 slots totally);
3. Two additional M.2 shields(9 has all three shields and 7 only has one shiled, check pic on official site);
4. Audio Card;
5. Base plate(something like a cover at the back of the motherboard);
Discussion Starter · #13 ·
Did you flash the latest BIOS? Check the updated changes info: Gigabyte added "Enhanced Multi-core Performance" allowing users to set all cores to match turbo ratio like x45. Also, check the FAQ please. It says Intel Turbo Boost 3.0 picks two cores to run at 45x, the rest will run 40x. With EMCP all cores will be boosted to 45x.
But always, to run all cores @4.5GHz, you have to make sure your cores won't go overheat. Or, the overheat protection will be applied. This may require high-end cooling system or a delidded cpu.
Hardware Enthusiast
I'm currently using F7a - the latest non-beta.
The issue with the AVX offsets isn't about the 45x turbo. It's about the "Auto" settings for the AVX/AVX512 offsets being completely messed up.
Discussion Starter · #15 ·
Did you turn AVX and AVX512 to 2 and 4? What can you get from these AVX settings?
Hardware Enthusiast
If you manually set the AVX and AVX512 offsets, the BIOS will do the right thing. As in drop the multiplier by exactly that amount compared to normal code for that particular core. And by doing that, I can get the behavior I want.
The problem is with the "Auto" settings. The "Auto" settings (all BIOS options at stock/default) applies zero offset for both AVX and AVX512 on both the 4.0 GHz all-core turbo as well as the 2-core 4.5 GHz turbo.
OTOH, "Auto" doesn't mean zero. If you mess with some of the other settings, it may be non-zero. But it's inconsistent, and it never seems to apply the offset when it actually needs to.
More context along with other people with the same problem: http://www.overclock.net/t/1632870/skylake-x-kaby-lake-x-combined-discussion/770#post_26214813
Discussion Starter · #17 ·
Yes, you are right. I checked the user manual(Page49) and it says Default:Auto, not zero. This will bring unstable number for AVX and AVX512 Offset because "Auto" means changing all the time. Silicon Lottery did AVX and AVX512 Offset at 3 and 5. You set them to 2 and 4. Did you see any obvious difference? Is it only a 0.1GHz difference for CPU frequency?
Hardware Enthusiast
Yeah, the multiplier offset is exactly what it is - a multiplier offset. So I currently run my machine at 4.2/4.0/3.8 GHz all-core turbo. (scalar/AVX/AVX512) The all-core turbo is 42x, AVX and AVX512 offsets are 2 and 4 respectively.
I have not tried to push the all-core scalar-code frequency beyond 4.2 GHz. Because of these offsets, we're basically doing 3 overclocks at once and there's no way to dial-down the voltages on a per-core/per-code-type basis. For example, let's say I can run all-core scalar-code @ 4.7 GHz. But to do that, I need to increase the vcore. But increasing the vcore will make my 3.8 GHz AVX512 overclock overheat.
Discussion Starter · #19 ·
I have not tried to push the all-core scalar-code frequency beyond 4.2 GHz. Because of these offsets, we're basically doing 3 overclocks at once and there's no way to dial-down the voltages on a per-core/pre-code-type basis. For example, let's say I can run all-core scalar-code @ 4.7 GHz. But to do that, I need to increase the vcore. But increasing the vcore will make my 3.8 GHz AVX512 overclock overheat.
Are you running Intel Turbo or locked all-sync frequency?
Hardware Enthusiast
Individual:
  • 1-2 cores: 4.5 GHz (4.3 AVX, 4.1 AVX512)
  • 3-4 cores: 4.3 GHz (4.1 AVX, 3.9 AVX512)
  • 5-10 cores: 4.2 GHz (4.0 AVX, 3.8 AVX512)
I kept the max turbo per core the same. So only the two "preferred cores" are allowed to reach 4.5 GHz. But any core is still allowed to do 4.3 AVX and 4.1 AVX512. IOW, the per-core turbo limit is applied *after* the AVX/AVX512 offsets.
1 - 20 of 612 Posts
