241 - 260 of 19450 Posts
Thanks that did fix it, but I’️m beginning to think I have a dud, XMP causes instability even though the RAM is on the list of compatible ones on the gigabyte site (I haven’️t yet manually set voltage as has been suggested on this thread though), then after disabling XMP and installing the nvidia driver and some gigabyte drivers, Windows went into a reboot loop and refuses to start up. Beginning to regret straying from ASUS.
try increasing CAS latency by 1 /forum/images/smilies/smile.gif
Thanks I’ll give that a try when I get my new board. I have a reproducible blue screen now as soon as I start gigabytes ‘app center’ (without XMP), so I’m pretty sure this motherboard is simply bad.
· Mr.4way SLI
Discussion Starter · #242 ·
Well it's the 13th and still no Cpu :(
Flare X 3200 cl14 bdie ocing on Aorus Elite
Still cannot get any good OC on my ram. Even using the safe settings on dram calculator. Getting super annoyed. Paid a hefty price increase for bdie. Could have got 32gb cl16 for what i paid for these.
Taiphoon
https://imgur.com/5jPvRhE
cpu-z(wont post @34 multiplier, highest i can go, set xmp profile, upped voltage to 1.45, and upped multi till it wouldnt post)
https://imgur.com/KLJqjjM
dram calc SAFE settings to get 3600(wont post with these settings)
https://imgur.com/Mpbd70x
What the hell am I doing wrong? Is this not good memory? If not I will just return them and get a 32gb 3600 kit
· Mr.4way SLI
Discussion Starter · #244 ·
Taiphoon
Try a manual OC not using the Dram calc. I see lots of people doing over 3800 easy with no issue
· Mr.4way SLI
Discussion Starter · #246 ·
Since someone posted a ""review"" video of the Aorus Xtreme..
(and no offense to the poster, comment would have been the same no matter the source)
Please be careful with what you post please, especially if it's a ""review""; meaning that if you have watched something before you link it here, make the extra effort and point out the inconsistencies, errors, etc; don't just paste vids.
99% of the sites out there spread the wrong information around, we don't need to do that as well.
When someone loads Prime to test an X570 mobo's chipset's temps ... need i say more? No :)
It's an excellent board, that has thus far not being graced with an excellent review; a very common phenomenon. Unofrtunately.
this has subtitles and you can use auto translate
Result 11min mark - 55.4°C average with 57.3°C max (chipset)
torture testing the passive cooling capacity using Ryzen 9 3900X with Prime95 w/AVX while playing The Witcher 3
PC Games Hardware (PCGH) has been around a long time and one of the few PC magazines that is still in-print (not just a digital presence) - https://www.pcgameshardware.de/
Aorus Xtreme has everything heatpiped together backplate, VRM heatsinks, x570 chipset (I might be wrong about that if so please correct me).
So Prime95 stress testing while having a game load in the foreground is a valid test to me.
https://www.youtube.com/watch?time_continue=8&v=KCMdu5ERZoA
· Tetrapyloctomist
Lacking comprehension is fine; they do too; which is also fine sadly, as that's what Youtubers are in their vast majority; just like every other random Joe, only with free toys.
The problem lies, again, when lacking understanding, we add our voice to that of others, until in the end a falsehood passes for truth. Not a novel concept, now is it.
Worse still when, rather than verifying, we insist on being correct because other millennials with free toys said so.
You want to test how hot this chipset gets, you put on a couple of gen4 NVMes, in the chipset controlled NVMe slots; you put one or two HDDs in the chipset controlled SATA ports; and while you're simulating some semi-intensive workload on them all (semi because we're after realistic stuff, not synthetic benchmarks), you simultaneously make sure your internet bandwidth is capped or near enough; if/when being also controlled by the chipset (see dual jacks). Again, simultaneously.
THAT is how you test THIS chipset, for TEMPS.
(do you even know what Prime does? Really, really does? Are you sure you do..?)
Unless again you're one of those people getting free toys and thinking freedom of speech = right to pass around whatever misinformation you like. Because "Youtuber".
('you' and 'we' figuratively)
With the F5G bios with a 3900X, PBO breaks with memory overclock, PBO works....Bios is very BETA, need more time for the platform to mature, anyone else having this? also how do I keep memory at 3733 at 1:1, 3733 on this board goes 1:2, isnt it supposed to be 1:1 up to 3733? Thanks my cpu max all core is 4.25 at 1.35V, 4.3 needs 1.41-43V temps creep into 89-92
if you have a Bdie kit. Set them to 3600 and try 16-16-16-36- 1 or 2 T and leave the rest on auto for now.
Cant get to post after I bump to 33 multi on 1t or 2t. Is there other voltages I need to increase besides the dram to 1.45? in the 101 guide he mentions 3 voltages, I only see 1 that is worded the same, the dram voltage, so I havent increased the other voltages he mentions in his guide. Is this the issue? If so where the hell is the "CPU VCCIO Voltage" and "CPU System Agent Voltage" in this bios?
https://www.overclockers.com/forums/showthread.php/785102-DDR4-RAM-overclocking-101-guide
I have my 3900x @4.3 all cores @1.325v. Im using ryzen master to oc tho, not the bios. 80-85c in bench
I was looking for cheap X570 Aorus Elite fit my budget but I look at VRM info and 16MB rom, I steer this.:thumbsdow
I have MSI X470 with 16MB and GSE-Lite :mad:.
I learned something new about VRM and rom size, I am sure you have seen those links below.
https://docs.google.com/spreadsheet...IVNyMatydkpFA/htmlview?sle=true#gid=639584818 :specool:
https://docs.google.com/spreadsheet...fiDZnKCjaXyzd1o/htmlview?usp=sharing&sle=true :thumb:
Who cares what ROM size is they don't support 1st gen Ryzen so there is more space on the ROM to support 2nd and 3rd gen. Also the VRM on x570 Aorus Elite is absolutely fine.
So, Prime95 won't put a thermal load on the x570 chipset on Aorus Xtreme because is somehow thermally knows to decouple itself from the heatpipes somehow. Good to know.
The X570 Aorus Xtreme is a over-engineered giant heatsink that could be used as art. See that would be an example of a fanboi post. Have you looked at the chipset temps of the competitions lineup.
BTW i take it back about what I said about your HR-55 as the HR-05 SLI/IFX is just fine.
der8auer's initial tests show that using PCIe 4.0 peripherals under stress doesn't make much of a difference to power consumption on X570 0.4W higher on NVMe Gen 4 than Gen 3 [both idle and load]
More testing is definitely need. Multiple NVMe Gen 4 drives configurations testing would be nice. der8auer thinks the X570 Aorus Xtreme chipset cooling is nice [end of the video].
SSD under load (running CrystalDiskMark for 15 minuets) using CH VIII and Corsair MP600 (3rd slot - chipset)
X570 Power Consumption Measured [English]
original der8auer video in German
[Summary of the video]
You can see that the X570 power consumption starts from a much higher base, idling at 7.35W with no NVMe drive attached. The yellow highlighted bars show max power usage der8auer observed with various combinations of NVMe Gen 3 and SATA drives, and one included a PCI graphics card running the FurMark benchmark too. Finally the bottom two results, in red, show power consumption when there is a Corsair NVMe gen 4 SSD attached, and in/active. Der8auer is surprised by how little difference there is between NVMe Gen 3 and 4 under load in terms of power consumption
https://hexus.net/tech/news/mainboard/132515-der8auer-examines-amd-x570-chipset-power-consumption/
I have my aorus xtreme in raid 0 with 2 2tb gigabyte pcie 4.0 but im running into bandwidth issues sharing my video card with my m.2 slot due my ps being to short ill have updated speeds tom but right now i am getting 3500 - 5800 read / 6000 write.
