301 - 320 of 19443 Posts
Will be getting the Gigabyte X570 AORUS XTREME after all with some issues with not getting delivery of some other parts I had tried to get earlier had to cancel those and try elsewhere and went with this overkill out of anger as it was in stock at least.
Will be pairing it with a Ryzen 7 3800X and putting it down under water with and try some 4x8Gb Micron E-die on it. Hope it works out and I really do hope the 3800X are better bin than the 3700X are.
Ah you got the other one from Inet.se? I had mine ordered from Komplett.se but they wanted 500:- extra and did not have it in stock so like you I cancelled it and got one from Inet instead. :)
Anyone with Elite that can tell how good/bad the Realtek® ALC1200 codec is sounding on this board? From what I understand there is quite a big difference between ALC1220 and ALC1200
I can confirm the same. I had this issue on my Aorus Master and I am still having it on the Extreme.
My issue is present regardless of whether or not PBO is enabled or disabled. If I OC my RAM any higher than 3566 or the Infinity Fabric higher than 1767 the CPU gets stuck in the 4.25ish GHz range. It doesn't downclock or boost when this happens.
I'm running into the same thing. 3900X, Master, F5g BIOS with F4-3600C17-16GTZ memory. 3532 is running better than 3600.
I'm also seeing weird behavior where it's not able to set CL 17 on the memory. I set memory voltage to 1.35 and XMP profile enabled. It detects CL 17 from the SPD. Auto and manually setting it to 17 actually runs CL18. If I set it to 16, it runs as 16.
What you are describing is definitely the behavior you get when memory training fails.
The screen stays black, the fans will ramp up for 30-60 seconds and then it will start into the bios reset screen.
This is the expected behavior of Gigabytes BIOS after it fails to POST a few times.
We've had a few guys in this thread with memory issues because the memory voltage was still at its default of 1.20v, so i suggest checking that.
Also make sure the memory is in slots A2 and B2.
Yep, this is exactly what was happening on my Aorus Elite. Selecting the XMP profile does not set the voltage. I had to manually set the voltage to 1.35 to use my kit and the XMP profile. I have not tried pushing it any further.
This happens to me as well haha. When ever I try to run an odd CAS it sets the to even number above. So CAS 13 runs at 14, CAS 15 runs at 16 CAS 17 runs at 18. Having Geardown enabled is SUPPOSED to allow you to run at odd times but it doesn't.
@GBT-MatthewH
Have you heard of any other reports outside of the 5 or 6 people on this forum of the 3900x no longer boosting or downclocking when set to RAM and Fabric clocks of 3600/1800 and above? At this point it has to be some kind of bug as I can repeat the issue very easily. Maybe I can make a video or something showing you exactly what is happening? Again this occurs whether or not PBO is enabled.
· Born-again Tweaker
I could be wrong but isn't it the opposite? I thought that disabling GearDown would allow you to run at odd CAS timings...
· Founder
Could someone upload a overclocking video of what there settings are with an aorus xtreme and a 3900x. I have mine running 4.3ghz on all cores but i would like to see how others are having theirs as well since i am learning still.
Hey guys!
I started a thread for X570 Aorus Xtreme owners, located here: https://www.overclock.net/forum/11-...0-gigabyte-x570-aorus-xtreme-owners-club.html
Anyway, Nighthog I am very interested in your endeavor with the Micron E-die kit.
I'm really having a hard time finding an E-die or B-die kit that is 2x16gb, since these boards are Daisy Chained, it'll be easier to overclock memory with 2 populated dimms rather than 4.
I'm getting really anxious to dive into this stuff with you guys. My 3900X wont get delivered for another two days but I'll be on vacation for two weeks when it gets delivered so i'm kinda going crazy coming to terms with that lol.
Hey guys!
This is e-die, correct? Not a great price right now but they've gone on sale a few times recently.
https://www.amazon.com/Ballistix-Single-PC4-24000-288-Pin-Memory/dp/B07MNJHJ2G?th=1
I went with 2x8 and now I'm wondering if I made a mistake, I may add two more sticks down the road -- hopefully 3600/C16 is achievable even with four sticks. (X570 Aorus Elite)
I will get my cpu and motherboard within 24hours but will probably keep it outside my loop at first until my new WC upgrade parts arrive, should be within 2 days for those. Need to check everything works before I rip out the old motherboard and cpu from the case. I can be impatient and rip it out right away, will have to see.
Rebuilding the WC really usually takes a day it all things work out. I went and ordered a WC kit for memory as well of all things so I hope that helps if I want to run higher voltages. I hope I don't break the kit if/when I put that on them in the end.
· Manual breath enabled
Sooo i got my cpu.
now i have a big problem with setting up my raid.
I have to set the Raidstuff to ON. OK
Now i cant see any Sata device anymore. BAD
I have 3 TB HDDs. One normal plate and 2 in raid0
How can i first get my nonraid disk to show up in windows WITHOUT formating the disk?
In the bios i MUST wipe the data to create a raid with with one disk. ***?
edit:
No raid settings enabled in the bios:
I see M2,ssd,1 hdd and one 3,65TB plate that i cant use in windows or even format hmmmm
edit2: created the raid over windows :rolleyes:
· Premium Member
@GBT-MatthewH
I'll be back in the office this afternoon to test. From what I gather this is what I'm testing:
Xmp not enabling dram voltage.
Does xmp allow downclock, speed and voltage.
Can you set odd timings.
Anything else I missed regarding memory? (not asking individual cases, just the general issues multiple ppl reported.)
Odd CL Timings work, but you do need to disable GearDownMode which is on by default. This is intended behavior of GDM as far as i'm aware.
From what i'm seeing the CPU cores don't reach their lowest idle power states when memory is as 3600, but do at lower clocks. Someone also made a thread about this on reddit.
Hey guys!
I'm worse :( I have everything I need to build my new machine right here on my side, except I can't find any mini-ITX X570 Aorus. All the stores that replied back to me have no idea when they'll get stock again.
So cmon Gigabyte, send some more mini-ITX to Europe... please!
Hey guys!
I don't have the best E-die looking at results others have achieved but will do what I can to push it to it's limits on this board. Seems the Crucial Micron E-die kits are getting better CAS latencies than the Kingston kit I have. I need usually much higher tRCDRD than those I've seen around.
I know someone mentioned it earlier but I can't seem to resume from sleep with 3900x and x570 master. I disabled realtek lan in bios like the previous post mentioned but I am still having issues. Anyone else having this problem? I usually don't use sleep but summer gets hot in my small PC room.
Over on reddit they who have boot trouble on MSI boards with Ryzen 3000 disconnected their reset switch from their boards and this somehow fixed a lot of troubles for many people with non-booting systems. Might be worth a try?
Sooo i got my cpu.
edit:
This youtube video helped me setup my raid 0 although there is other ways also.
There is another video shorter but it did not help me solve the issue into booting it seems to have renamed the hdd when it needed to go into raid 0 format which is what threw me off for so long.
also if you going to install it from windows setup make sure you do the directions on here it does work.
· Premium Member
From some rough testing-
Mobo: X570 Master
CPU: 3600X
BIOS: F5G
Default (no XMP) - Voltage goes to .9, clocks to 3600Mhz
XMP 3600 - Voltage stays at 1.4V, clocks 3600-4000Mhz
XMP 3400 - Voltage around 1-1.1V, clocks 3775
XMP 3600 / IF 1700 - Voltage 1.4V, clocks 3600-4000
XMP 3400 / IF 1800 - Voltage 1-1.1V, Clocks 3775
From very quick and dirty testing it points to clocks/voltage not downclocking with 3600+ memory. I will pass along the feedback to the team and see what they say. I do not know if this is a GIGABYTE or AGESA issue, I can only confirm the same findings as the rest of you.
* Also, all my XMP tests correctly applied 1.35V for DRAM.
