341 - 360 of 19441 Posts
Is this only 3900X? Anyone else with another CPU? Just to be clear just go to start -> sleep then it won't resume? Does the debug LED say anything? What board?
Personally I only have 3600X right now to test, but if I can gather enough info to try and reproduce I can have HQ test.
I also have a 3900x. I have noticed that when my PC tried to go to sleep all my fans shots up to 100% and just stayed there. My RGB lights reset back to that factory orange and my PC become unresponsive. I haven since disabled sleep, but when I get home I will try again and report if any meaningful codes appear via debug LED. Do note this was on my Master board, I have the Xtreme now but still haven't tried putting it to sleep. Still I will test when I get home.
What are the CPU voltages across all cores when idle and under full load on a 3900X? I am getting 1.48 idle and 1.35 under full load across all the cores. Does that sound correct?
Nevermind, even though I had though I had closed all monitoring software and just had CPU-Z open, turns out iCue software was running in the background and causing the wakes.
@ GBT Matthew
My sleep issue was with 3700X and Corsair CX750M PSU
the system sounded like it was waking up but the monitor stayed black and even the "shift+Ctrl+Win+B" to reset display driver did nothing. I do not recall if debug code if it was even on.
For my setup setting the Power Supply Idle to typical in bios and disabling fast startup under win 10 1903's power settings worked for me and I haven't had any issues for sleep since.
My only issue now is the vcore is locked @ 4.65ish while idle but does drop to 1.35 or so under full load so it is more of an annoyance than a major issue for me.
I read somewhere that someone noticed same behavior and had to do a reinstall of Windows and not install Ryzen Master to have vcore drop while idle. Maybe Ryzen Master modifies some registry values or something. Not really a viable solution as Ryzen Master is the only tool for now that will show RAM timings, voltages, Fclock speed, OC mode, etc
Kind of low. Should be closer to 4.325-4.375, check your cpu temp. If you use an AIO try full speed and test again.
going to test again today I am using a h150i but to clarify what i was saying, optimized defaults with xmp enabled I boost to max 4.55 single core and everything in between when I overclock the ram i'm stuck to 4.25 max and minimum.
Your post earlier explained a work around to get the cpu to downclock again but i'm curious if maximum boost is being affected as well, i'm going to try myself here shortly but a test sample of one doesn't say much.
· Premium Member
I didn't pay attention to specific boost speed when I tested, however I can say my CB15 score was identical with both power plans. So I assume the boost was also the same.
well good news it does appear to help, voltage is not going down nearly as much as straight stock/xmp and i've lost about 50 mhz off max boost but the performance benefit of the higher ram speed/if counters that enough.
@ GBT Matthew or anyone else with the answer
This is my 1st Gigabyte board so I am unfamiliar with some of Gigabyte's features or terminology.
On the Tweaker page under XMP profile there is an option that says XMP High Frequency Support with options Auto, level 1, level 2, and level 3 what is this?
4x8GB RAM not Posting
@gbt_Matthew just wanted to let you know i have the x570 Aorus Ultra and my Ram 4x8gb 4133mhz Patriot PVR416G413C9K does run on a 4x8gb config with xmp 4133 or without if i put 4 dimm,s in i can not Post, not with any of the available bios versions, not even with cmos clear only 2 sticks work but individualy all 4 sticks are ok.
· Premium Member
Those XMP settings are for (2) sticks not 4. You can try the ryzen calculator to get timings for 4 sticks. For reference I can do 2 sticks @ 4266 (the rated XMP profile) with my hyperX ram. If I use 4 sticks I have to drop down to 4000Mhz. I havn't had time to play with getting all 4 sticks up to 4266. Instead I focused on 3600Mhz and getting the timings down to CL14 at IF 1:1. Still tweaking settings but promising so far.
Thanks for the super fast reply but i know how ram overclocking works and i run them @3600mhz with tighter timings if i could get the system to post at all with 4 Slots occupied. if i put all 4 RAM modules in the system it will not post, not @jdec speeds not if i clear cmos nor if i downclock it to 1600mhz with 2 sticks in the system as soon as there are 4 sticks of ram the mobo will just not post at all.
· Manual breath enabled
CAs14 is hard to get. cant even do CAS15^^
So far this settings are stable. any thought what i could tweak more?
I have just been running 3200mhzC14 with infinity at 1600; my voltages are very very high while browsing the interwebs.... seen on Ryzen Master and CPU-Z. 1.4-1.5v pretty constant. This being just XMP enabled and downclocked to 3200c14 and the infinity fabric clock changed. Otherwise all stock as of right now.
Not sure whats up with that. My E-Die showed up today, might test it a little bit later... see how it fares compared to the B-Die.
· Premium Member
Page 33 has your answers, this specific post may help while we await new AGESA - https://www.overclock.net/forum/28046610-post325.html
I would try each stick, each slot, to narrow down the problem. Posting 4 sticks at default shouldn't be a problem. You can also try manually setting voltage with 1/2 dimms then adding 3/4.
I literally just used this guide :) https://old.reddit.com/r/Amd/comments/cdneto/overclocking_your_memory_from_one_newbie_to/
snip
Anyway, Nighthog I am very interested in your endeavor with the Micron E-die kit.
I'm really having a hard time finding an E-die or B-die kit that is 2x16gb, since these boards are Daisy Chained, it'll be easier to overclock memory with 2 populated dimms rather than 4.
snip
I had the same issue even using the B-Die finder tool. I wound up finding a G.Skill 3200 14-14-14 B-die kit. I think I paid ~$260 w/ shipping.
Can you note where this setting is located?
Sure,
press F2 for advanced mode if you haven't done that already.
should put you on the Tweaker page where you will find "advanced CPU settings" 3rd or 4th from the top then set "Power Supply Idle" to typical and see how that goes for you.
· ⤷ αC
Gigabyte X570 AORUS Pro Wi-Fi Review
https://www.techpowerup.com/review/gigabyte-x570-aorus-pro-wifi/15.html
RightMark Audio Analyzer (Aorus Pro/Ultra use ALC1220-VB while Aorus Elite uses the ALC1200).
I haven't seen any reviews on the Aorus Elite yet.
The rumor mill site wccftech reviewed it as well and had the same note about missing post code / debug LED:
https://wccftech.com/review/amd-ryz...pu-review-x570-aorus-pro-wifi-motherboard/11/
Also for the PCH , the Aorus Master heatsink seems fine and on par with MSI Ace
https://www.tomshardware.com/reviews/gigabyte-x570-aorus-master-atx-motherboard,6227-3.html
Tom's hardware has an unusual con: Steel back cover adds a pound of unused heft
Apparently they didn't notice it cools the power delivery. :rolleyes:
