421 - 440 of 19450 Posts
· Mr.4way SLI
Discussion Starter · #422 ·
Is anyone running Raid 0 on their X570? if so how do you set it up?
· Manual breath enabled
Wanna share my newest performence settings:
In bios:
Vcore to "normal".
The voltage below to "normal"
Under the XFR settings change PBO to "enabled".
Under the other PBO settings to "Disabled".
Powerplan "high performence" minclock 1, maxclock 100.
This way i get low idlevoltages + highest single and multi performence. Boost up to 4,525Mhz. Saw one time 4,575Mhz.
Some results with the different XFR/PBO combis. Testet in CPU benchmark, because faster^^
XFR(0,9-1,47V)
535,9
8391,2
XFR+PBO(1,32V)
525,0
8287,9
PBO(0,9-1,47V)
535,1
8239,2
All disabled
534,8
8205,9
Hope this will help some here
Just ordered the X570 Master. Even though I would prefer the Xtreme due to the completely fanless design, I couldn't justify the price increase. And I trust that the users of the fan-stop BIOS versions are happy.
· ⤷ αC
Afternoon,
I got myself the Gigabyte x570 Ultra with the 3800X. I updated to the latest BIOS F4F, however I'm having one hell of a time to get the system to boot(system turns on but I'm staring at a blank screen) with two Gigabyte 980 Tis in SLI. When two cards are plugged in, the diagnostic VGA light on the motherboard is on implying that there's an issue with the video connection.
If I connect only one card (whether it be the top(PCIEX16) or middle(PCIEX8) slot) the system boots fine. If I connect the cards to the middle(PCIEX8) AND bottom(PCIEX4) slot in SLI the system boots & the motherboards diagnostic VGA is off (as should be when it works).
DOES BOOTS:
TEST 1
PCIEX16 - Occupied
PCIEX8 - Empty
PCIEX4 - Empty
TEST 2
PCIEX16 - Empty
PCIEX8 - Occupied
PCIEX4 - Empty
TEST 3
PCIEX16 - Occupied
PCIEX8 - Empty
PCIEX4 - Occupied
DOES NOT BOOT:
Test 4
PCIEX16 - Occupied
PCIEX8 - Occupied
PCIEX4 - Empty
I've tried this on all 3 available BIOS: F2, F3 & F4F with all the same issue. I've switched BIOS to GEN 4 only, GEN 3 only and used both those configuration with switching the Bifurcation between Auto, 2x8 & 1x8/2x4.
Am I doing something wrong here? Any advice would be greatly appreciated.
PS Just for reference the manual does state I'm suppose to use the top(PCIEX16) or middle(PCIEX8) slot when doing SLI.
· Triple Screen Enthusiast
I'm glad this is helping some people. A few others said it didn't work, so I'm not sure what's going on with these power plans. I tested through a few BIOS and all the Power Plans/Settings and this is the only setting that lets my vcore drop to <1.0v like AMD demonstrates.
check both cards if there is any video output. i had the problem, that the secound card goot detected as the main card and i had no video on the other top card. You can change that in the bios. wich is main
Thanks for your input. I did try that already, I just forgot to add that above.
As for good measure I'm going to try again. I will post an update.
New information: I tried what you suggested and to results were the same, I even went as far as testing each port individualy (all 4 on both cards so a total of 8 ports, the DVIs were not tested due to not having a DVI capable monitor) however I did discover something else.
The system does boot, I know this because I can hear the Windows startup sound. I also again for good measure toggled between the "Display First" options. Also interesting enough I left one card in (which does boot fine) and disconnected the monitor cable the VGA troubleshooting light stayed on (I guess it know that the cable isn't plugged in) then plugged the monitor in(after windows booted) then I got a display however the light remained on. Something tells me this is a big in the BIOS but I'm not sure.
Hello Guys
I bought today Gigabyte AORUS X570 Master
I'm having problem to run my memory at 3200 with xmp and without , i tried run at 3200 with 1.35 v and 1.36 but cant boot at windows. After a lot of tries i managed to boot and play some games at 2900 ram speed with 1.35v.
I have the Corsair Vengeance 32 gb with 4 dimms , 4 8 gb https://www.corsair.com/eu/en/Categories/Products/Memory/vengeance-lpx-black/p/CMK16GX4M2B3200C16
Anyone else has problem with running at 3200 , is there something i can try some settings ?
Thanks
I just got a Aorus Master and 3900x up and running. I am having issues with the XMP profile for my ram. My PC will boot with the XMP profile but will BSoD after awhile. I ran memtest86 at stock ram settings and there are no errors after 1 pass but using the XMP profile I get 400+ errors before even one pass completes. I don't know if that indicates bad ram or the XMP profile is not stable. I am not getting any BSoD at stock ram settings during general PC usage.
I have a CMK16GX4M2B3600C18 kit which is on the QVL as I understand it should work. The XMP profile name seems odd in the BIOS as well showing DDR4-3500 but under advance settings it looks like the correct "System Memory Multiplier" of 36 is being selected.
did you set the voltage to 1,35V? the board dont set the voltage for the xmp
Reactions: AlphaC
That seems to have fixed it. I ran a full pass of MemTest86 and no errors reported using the XMP profile and the DRAM voltage set to 1.35V.
I did not know you needed to manually set the DRAM voltage for XMP. I though using the XMP profile set everything for you.
· Tetrapyloctomist
GB-Matthews, assuming you're at liberty to discuss this;
Any reason why the Xtreme has both LAN phys wired to the chipset? I remember seeing an AMD published diagram showing how the CPUs allow for one to be wired directly to them, only this isn't the case here? Why.. :)
I think there is problem with 4 dimms to reach 3200 with xmp and 1.35v manual , at the moment i can only reach with 28 multi at 2800 stable
Not a problem over here, must be a compatibility issue with your kits. Or your setting some setting wrong. Could be your brand/make of memory is just bad.
I can boot 4x8Gb 3933Mhz stable with XMP in asynch mode and 3800Mhz in 1:1:1 mode working stable. With the memory kits I have.
___________________________________________________________________________________________________________________
@GBT-MatthewH
I found another issue with the BIOS F3e on X570 Aorus Xtreme motherboard regarding sleep function.
When you resume from sleep your SoC Voltage is reset/ignored from what you have set in BIOS. It goes back to stock/AUTO 1.100V on resume. I
I had it set with a offset: VCORE SOC [normal] -> [-0.0750V] before I put the system in sleep and it's gone back to stock on when I got back into Windows. It should have been 1.025V with how I setup it in BIOS and was as such before I tried the sleep function again.
I haven't checked the other voltages as I haven't found a need to tinker with them, but it could be wise to go over them in your testing to see which function as they should using sleep/resume. It's a possible source of problems when settings aren't remembered/reset when using sleep.
There is also a issue with duplicate entries for settings in [AMD CBS] & [AMD OVERCLOCKING] It is regarding the Data Fabric multiplier, Manual setting.
The one in AMD CBS -> XFR sub-menu works up-to 1800[3600Mhz] without issue. But you have trouble above, it could boot 1833 but it would crash on any load when in windows. Anything above would not boot at all. tried various things but could not get it to work.
The one in AMD OVERCLOCKING When set manually functions without issue all the way to 1900[3800Mhz]. Just set it and it worked without issue.
It's a little odd the same function behaves differently depending on where you set it.
