461 - 480 of 19443 Posts
Gigabyte x570 Pro Wifi with 16GBx2 3200 Ballistix LT sticks, the AES version that is QVL. Board doesn't always boot, cycles between CPU and DRAM according to the red boot light on the board. Tried running ram XMP and standard speed, same issue where sometimes it boots through, sometimes it doesn't. I have 2 sets of these sticks, tried 1 stick at a time in each of the 4 slots, same issue, sometimes boots, sometimes doesn't.
Chances of it being a bad board? Bad RAM? I have a 3rd set coming from Amazon, since the previous 2 sets came from Newegg, just to confirm it isn't the RAM, but wanted to see if you guys have been having these issues with Gigabyte boards.
If it's the board, which I'm like 60% sure, replacement with Newegg is going to be a pain. I have a feeling. Besides, Front audio header doesn't work well for the microphone as all I get is static noise where it suddenly happened one day; the front headphone works though, as does the rest of the ports in the rear.
· Mr.4way SLI
Discussion Starter · #462 ·
I am running raid 0 on two 660p Intel drives via the chipset. What are you having trouble with?
I'm running an NVme drive for boot. But I have a pair of 256gb ssd that I want in Raid0 and and 2 480gb I want in Raid0 and I can't even get either pair to raid.
· 486DX2 66
@bucdan why would a replacement from Newegg be an issue? Are they out of stock or something?
I have the same board arriving today (CPU hopefully today as well but its in another package) from newegg, will see if I have the same issue
Thanks for the reply @Nighthog I'm really looking forward to it and this new build. I haven't built in 10yrs, I'm still on X58 1366 socket, heh, so I've been out of the loop on new features etc. so any insight and advice is appreciated,
Cheers
Thanks a lot i found it , the problem was that for some reason the motherboard had switched to the 2nd bios which had the old bios ...
This board has a "dip switch" by the Debug LED that disables that behavior and allows you to specify which bios you boot into with the switch above it.
Sometimes they can be sticklers when it comes to getting replacements.
· Old dog, likes new tricks
Did you set the RAM voltage manually? If not, try it. There's a bug where even with XMP, your RAM will default to 1.2v. Force that to whatever your RAM says it's supposed to be (assuming 1.35V).
I'm on the Aorus Ultra and got myself the "Corsair Dominator Platinum RGB 32GB (2x16GB) DDR4 3466 (PC4-27700) C16 1.35V Black" even tho they were not on the compatibly list. They worked right out of the box , I wouldn't be surprised if they worked for you as well.
Thanks, I was thinking of the Trident Z just cause of the price (it's dropped a lot since I first found the kit) but since i"m not going to be running my Noctua DH14 any more with this new build I don't have to worry about ridiculous height RAM either. Any RGB issues with the Corsair? I'm assuming you have to use the Corsair software? Or can the Gigabyte RGB Fusion control them?
RHB Fusion cannot control the memory RGB. I do not really care to change them tho. I'm going to water cool my cou so do not care about the Ram height.
· Born-again Tweaker
Just tried DRAM OC for the first time w/ Ballistix Sport LT 3000/C15 using Ryzen DRAM Calculator's "Safe" values (CL16) for 3466MHz (Aorus Elite, 3700X). Set voltage to 1.39V which was recommended. Ran some Memtest64 w/ no errors, but only about a half hour -- not sure how long to make sure it's really stable. Cinebench Multi Score went up around 200 points from the stock 3000MHz profile. Looking forward to pushing it more.
· Premium Member
@GBT-MatthewH
Could you check the compatibility with ram 4 x 8gb 3200mhz
I have the Corsair VENGEANCE® LPX 16GB ( https://www.corsair.com/eu/en/Categories/Products/Memory/vengeance-lpx-black/p/CMK16GX4M2B3200C16 ) 4 dimms of that so 32gb
Anything i tried over 29 multi doesnt boot in windows even with 1.35v manual , at 29x im ok but if i go a little higher 30 it doesnt boot in windows
Gigabyte x570 Pro Wifi with 16GBx2 3200 Ballistix LT sticks, the AES version that is QVL. Board doesn't always boot, cycles between CPU and DRAM according to the red boot light on the board. Tried running ram XMP and standard speed, same issue where sometimes it boots through, sometimes it doesn't. I have 2 sets of these sticks, tried 1 stick at a time in each of the 4 slots, same issue, sometimes boots, sometimes doesn't..
Make sure you are using A2/B2 slots.
· Triple Screen Enthusiast
RGB Fusion can control GSkill Trident RGB. Run as Admin and it should show up. But I also noticed a lot more vcore fluctuations with RGB Fusion open. If you force close it from Task Manager, your custom colors stay, but if you close it normally it reverts. So my fix was to write a quick startup script that ends the RGBFusion task on startup. So it applies my theme, then ends itself.
Also i would like to see to the debug led an option to change the led from bios so we can see the cpu temperature.
I had this option to my asus motherboard and i saw that also asrock motherboards has this option to change it
Thanks, it's good to know about the GSkill stuff. I figured the Corsair wouldn't but wasn't sure. My current built is like 4.5 years old and has no RGB inside the case so I don't know if some of the apps can control other mfr's stuff etc.
Will give it a try tonight.
Mhmm. I'm certain, second slot from the left, and last slot to the right. Oddly enough, when I get into the BIOS, the board says "Unknown" for the manufacturer. I've seen people's BIOS actually say the manufacturer of the RAM. I have another set of RAM coming in from Amazon to be certain it's not Newegg giving me the short stick for the two sets I ordered from them at the same time. Else it's the board.
Latest BIOS version as well, optimized defaults, etc.
EDIT: Just saw that Gigabyte is doing some freebies for reviews, sweet. What's bad is the need for Facebook to even submit it :(.
Hello Guys
I bought today Gigabyte AORUS X570 Master
I'm having problem to run my memory at 3200 with xmp and without , i tried run at 3200 with 1.35 v and 1.36 but cant boot at windows. After a lot of tries i managed to boot and play some games at 2900 ram speed with 1.35v.
I have the Corsair Vengeance 32 gb with 4 dimms , 4 8 gb https://www.corsair.com/eu/en/Categories/Products/Memory/vengeance-lpx-black/p/CMK16GX4M2B3200C16
Anyone else has problem with running at 3200 , is there something i can try some settings ?
Thanks
I'm running 4 x 8 GB sticks of G.Skill Trident at DDR4 3200 Timing 14-14-14-34 without any problems on the x570 Master.
Hmm i dont know then maybe it's a compatibility thing with these specific memories ( model ) and 4 dimms, it goes only to 29 multi
I wanted to report some strange behavior.
Working on my 3900x and X570 Aorus Master - the chip will not boost past stock clocks still, maxes out 4250 to 4300 single core/gaming and 4050-4075 multicore loads. PBO via the bios, in all forms, does not work at all. Ryzen Master PBO does work, but doesn't affect top boost clocks. PBO levels in Ryzen Master default to max PPT/TDC and EDC values. EDC will not budge past 157A, but TDC maxes out at the stock 95A. Setting TDC higher, to say 120A, makes no difference, it locks at 95A. I dunno what's holding me back, but TDC being the only value maxed out seems suspect.
Temps are fine, newest chipset drivers and bios. Also worth noting is CPU+SOC with bios only PBO is stock 116w, while Ryzen Master enabled PBO is 197w.
Additionally, I decided to experiment with some ram today. The ram I have in my build is Gskill Trident-Z 8gbx2 3600 CL14 ram, Bdie. I swapped those out today for some older Gskill Vengeance 3200 ram I had around, 8gbx2 as well. Boost clocks went up 125mhz, R15/20 scores stayed on the high side of the same. It seems this ram, or ram in general, can affect boost clocks? I'm not sure.
I'm running the 3900x and X570 master as well and I can't seem to hit max rated single core no mater what I do either but not as bad as your seeing. All core seems to stay around 4200 MHz all the time and single core gets up to 4525 max. Temps never got over 49 C during the benchmark.
