741 - 760 of 19441 Posts
· Not that new...
@Raisin_334
I'm getting a 02 code on the latest F5K for the Aorus Master when trying to boot to the Bios. Everything has been running OK in that regard since I bought the board (F5G and shipping Bios). I've tried clearing the CMOS, unplugging every uneeded USB device and shutting off the PSU. Anyone else in my situation? Seems to be able to boot to Windows half the time though. I've also tried using Windows to boot to UEFI and I still have the error.
Edit: Might be D2 code? 02 isn't in the manual.
snip from my post here https://www.overclock.net/forum/28067048-post679.html
Cold boot from Windows shutdown OK
*** Cold boot from Windows shutdown + turn off power supply (aka; pull mains power) *** Boots to black screen, Debug display shows <02>, keyboard still responsive to CRT-ALT-DEL and HD activity light flickers. If I CRTL-ALT-DEL or hit reset, the system will reboot to windows normally. If I stop the boot and enter BIOS there is no message warning it was reset and all settings are as they were. This behavior is repeatable but, is not consistent.
I saw your post and it got me thinking that perhaps its not the known issue with PSU power off ... I haven't messed with my monitor or different display ports on the GPU. I'm actually trying a test bios out now that is supposed to correct the bios reset after psu power off issue, thinking that was what was going on with my board. I'll have to reload F5j and test out GPU and Monitor ports.
It's weird, I was playing around in the Bios and I was able to find a configuration section for the UEFI display driver for my 2070 Super FE where I could choose a default output but I've not been able to find the menu since. That's weird. Maybe it's a hidden menu of some kind or it's right in my face and I can't remember where I went. Everything is working though so I doubt I'll lose sleep over it.
Can you tell me the exact settings you are changing, the fan header(s) you are using, and the motherboard + BIOS? I just did a quick test and the fan profiles worked after sleep -
Go into BIOS and set fan speed to 0 up to 80C. Basically off.
Sleep system.
Wake system - fans kick up for 2-3 seconds then turn off. If the profile was resetting they should be spinning some.
I also did the same test in reverse, with fans set to 100%. They ran at same RPM before and after sleep.
Not the one you quoted - but can you try it again with the fan connected to CPU_OPT? Manual fan curve (something reasonable). After resuming from sleep, it's spinning at 100%.
@Raisin_334
After all this is said and done, I'm pretty sure those black screens with the post code stuck at different values were a situation where I was in the actual BIOS, it just wasn't outputting to the right display.
· Premium Member
Ill try tomorrow, today I tested sys fan 2 + 4 on master. If anyone has steps to reproduce the issue consistantly let me know. In general if I can give our team an easy way to reproduce an issue, we can fix it pretty fast. Its reproducing it that takes the longest.
Just updated to F5K on the Aorus Master - 3700X, 16Gb ram running at 3200Mhz, PBO on in BIOS, latest chipset drivers and power plan set to Ryzen Balanced.
Idle voltages in CPU-Z are going as low as .9v and idle clock speed is 3.5Ghz. CBR15 score of 2179 and HWINFO64 is showing boosts of up to 4.375Ghz on single cores at 1.388v.
Only problem I'm still encountering is idle voltage locked at 1.44v and 4.2Ghz when iCue is open. Otherwise, everything working as intended.
Have also noticed on cold boots/restarts after displaying the Aorus logo, QLED will switch between codes AE and Ad about 5-6 times, my screen will flash then after about 15 seconds it'll boot in to windows. My boot priorities haven't changed so no idea why its doing this.
Here's how I can reproduce it:
Specs:
3700X on Aorus X570 Elite with today's F4i BIOS
Windows 10 1903 with all the latest updates
Yesterdays AMD chipset driver, selected AMD Ryzen Balanced Power Plan
All "monitoring" and background apps and services are closed in Windows
No Gigabyte-software installed whatsoever, everything done through BIOS
This fan (3pin!), one plugged into CPU_OPT, one plugged into SYS_FAN1.
Steps:
  • Went into BIOS, selected "Load optimized defaults"
  • Restarted, went into BIOS to make sure everything and especially the fan curves in Smart Fan 5 were all reset and on default
  • Restarted, booted into Windows
  • Closed all apps, services, no monitoring tools and waited 2min for everything to "calm" down
  • Start -> Power -> Sleep
  • Waited 1min, pressed some key on my keyboard to wake the PC up again
  • Immediately can hear one fan is full throttle, it's CPU_OPT. Waited a few minutes, it's not calming down. The same fan model in SYS_FAN1 seems to behave fine.
  • Opened HWINFO64 to double check, CPU_OPT spins at over 1000rpm (it's a 140mm fan) while SYS_FAN1 is at ~500rpm and so are the other fans.
  • Start -> Power -> Restart
  • Fan still 100% but sometime towards the end of the long post (right before you hear the post-beep) the fan seems to finally load its proper profile and calm down
I did another run to see what the fan RPMs are in HWINFO64 after Windows boots. After everything settles, all the fans (including CPU_OPT) are around 400-600rpm. Running Cinebench causes the fans to spin up properly and then return to normal speeds again after I close Cinebench. Doing the same after a sleep-cycle, CPU_OPT will always stay at >1000rpm while the others spin up and down again correctly.
I hope this helps. Maybe it's some sort of weird fan incompatibility. But then again, the same model works fine in SYS_FAN1. I thought maybe my CPU_OPT header is maybe broken or bugged or something, but too many people seem to be having the same issue.
· ⤷ αC
· Premium Member
Specs:
Steps:
Perfect! I'll try tomorrow.
Hi Matt
Regarding the fan 100% issue
For me i have 3 fans connected.
1 on CPU_OPT
1 on CPU
1 on System
BIOS is running the latest posted on first page on 570 WIFI Pro (Atx) with 2700x
Set all the profiles to silent
Power on PC
Sleep
Wake up and fans will be at 100% and stay at 100%
A reboot will bring the fans back down to silent, I posted the temps in an earlier thread
I’m one of those affected by the cold boot issue after main switch has been turned off. Using x570 pro wifi. The below are the things that I notice:
1) When it happens my screen will be totally off, just like pc turned off.
2) The mb RGB light also will not light up.
3) notice the debug led light up in this order: upon pressing PC on button,
- cpu debug led will light up, then turn off
- ram debug led will light up next. This will light up for about 10-20 secs before it turns off and cpu debug light turn on again. It is a looping cycle over and over again. Need to force PC to turn off by switching off mains before I can proceed to next step.
4) After turning off main switch, remove psu cable , proceed to perform clear cmos.
5) turned PC back on and it will boot up to bios if the mb RGB lights up. ( encountered 1 time it didn’t and no matter how many time I tried clearing cmos, it will be looping over and over again no end. Refer to step# 3. In the end need to use Q-Flash Plus to flash the bios. This is the worse case scenario )
6) once in bios, there will be 2 scenario.
- #1 will have message stating bios reset to default due to cmos cleared which is normal.
- #2 same message as #1 BUT the bios version will be an earlier one. ( from F4i down to F4f)
Seems like during step# 3 the looping are causing the system to try booting to the dual bios one by one, thus the endless looping. There may corrupt the bios which i encountered that need to be resolve by Q-Flash Plus. However, if the bios chip/memory are damage, even Q-Flash Plus will be useless.
I know that Matt and team are currently working on a fix for this cold boot issue.
I really hope this issue will be resolve soon enough as it is really very inconvenient and i myself feels frustrated for the need to troubleshoot the pc whenever we want to use it. If I’m around still not too bad although it will take around 5 to 10mins before the system boot to windows for the use of the PC due to troubleshooting. Problem is if I’m not around and my kids or other family members need to use it then how???
I flashed my X570 Master BIOS and my RAM is around 5C cooler than before, how's that even possible with the same voltage as before? It's freaking awesome since it was getting a bit toasty anyway.
I've also seen 4.35GHz on a single core after the update on my 3600X, unfortunately still not the same as before, I was running an Asus Strix X470-F with Agesa 1002 and I've seen 4.3GHz allcore in games with single cores boosting to 4.4GHz with the same CPU. It's probably not a big deal in terms of performance but still it would be nice to see this again since my CPU is definitely capable of 4.4GHz. (Attaching a screenshot of old boost behaviour on Agesa 1002).
Updated my bios to the latest F4i on mine Elite.. 3600x
The IF and RAM speed is now fixed for me, it's in sync with ram on 3600Mh IF 1800. The CPU now boosts past 4150Mh, previously it was stuck there and wouldn't boost only when I changed the ram speed to 3533mh.
I'm still not getting the boost clocks that I got on the out of the box Bios. Boosts to 4,4.... mine boosts to 4292mh.
PBO and AutoOC still don't do nothing for me, on off same, all core burst in cb15 4167mh, single 4292mh. Temps max 75c strestesting.
Didnt test the Bios reset thingy when you unplug your PSU power cord...
Edit: damn i just saw when i created my acc here on OC.net in 2007...Man im old :D
Is the compatibility with 4 dimm of ram is better with new bios ?
I'm on vacations so i cant try the new bios but i hope it has been fixed the problem i have with my 4 x 8gb ram where i cant run it at 3200 even with xmp , it only run at 2933
@gbt Matthew
I flashed the F5K bios yesterday and all was well until I powered off the PC over night. Turned it on this morning and it would not post. Got stuck just before the splash screen where it is all black and there is a - sign in upper left corner (just B4 Auros logo). Debug said 64. Which the manual says CPU DXE initialization started. Using the same "auto" settings plus XMP 3600 16,16,16 profile as used on all earlier bios versions without boot issues
Had to use Flashback to roll back to F5J.
3700x
16GB G Skill F4360016D-16GVK
512 GB Samsung 970 evo boot drive
RX Vega 64 Liquid
Corsair CX750M
Edit: I read over on Reddit that other users of the 1.0.0.3 ABB Agesa noticed that the dram voltage is stuck @ 1.21 no matter what you set manually and could be why I couldn't post
here: https://old.reddit.com/r/Amd/comments/ckmeyl/1003abb_dram_voltage_bug/
· 3x420mm rads!
I'm experiencing a strange DDR voltage bug on the latest 1003ABB (F4h on my mobo), I explained it here:
https://www.reddit.com/r/Amd/comments/ckmeyl/1003abb_dram_voltage_bug/
but the essence of it is:
If CPU frequency is manually set in BIOS, DRAM always runs at 1.212V, regardless of its own setting. It isn't simply a display bug.
Relevant info: Aorus x570 Pro, 1003ABB, 3900x, 3600mhz CL17 memory running at XMP.
Maybe your ram is running at 1.212v like mine? I expect you might get some sudden reboots when that voltage proves to be insufficient =/
I also had much cooler ram but right below my ram temp readout is my ddr voltage readout so it was clearly off lol
DRAM voltage works fine with manual all-core-OC on the AORUS XTREME F3H AGESA 1.0.0.3ABB.
Add on for x570 pro wifi bios version F4i.
Xmp profile enabled and set to [email protected] in bios. Boot to windows and verify ram speed @ 3200MHz. Restart pc, able to boot back to windows successfully but found ram speed running at 2133MHz instead but timing is for 3200MHz(16,18,18,36,54). Go back to bios and found Xmp profile still enabled and multiplier still in auto mode.
For some unknown reason, the ram speed revert back to default even thought Xmp is enable and multiplier set to auto .
· Old dog, likes new tricks
I saw the same thing happen with F5K on the Aorus Master. But it only happened once, so I chalked it up to a memory training fail or something. One reboot fixed it, rather odd.
