Can anyone test if EDC bug still works on F20a?
Already done, bub.EDC=10 works for X570 AORUS XTREME F20a AGESA ComboAM4v2PI 1.0.0.2, we also have unlocked AMD_CBS menu, all the settings you want and more to tinker with.
I can confirm it works. But not as good as before for me.Can anyone test if EDC bug still works on F20a?
did u check your watt on cpu package, i cant seem to get past 145 w no matter the settings, might be why, clocks are high but yea i only get 145w power draw so thats why my scors are same as defult.I can confirm it works. But not as good as before for me.
Very swinging scores in CPU-z, very stable but low scores in CB20.
Don't know cause my PPT is configured at 135.did u check your watt on cpu package, i cant seem to get past 145 w no matter the settings, might be why, clocks are high but yea i only get 145w power draw so thats why my scors are same as defult.
You nailed it!! was going crazy over CB20 reboots until I set the SOC voltage to Auto!Here's my first feedback about F20a... TLDR; I'm probably going back to F12a soon
The good:
- Unlocked settings in AMD CBS
- PMU pattern bits can be now configured manually
- Better memory compatibility (can run CL16 with GDM Disabled now)
- ProcODT at 60 with XMP profile fixed
- Can now run VDDP/VDDG at 1000/1050
- Better UI graphics...
The bad:
- IMC is broken; memory bandwidth (Sandra) at 3800 MHz is much lower than F12a, almost same as when configured at IF 1800/3600 MHz.
- Memory latency is different (Sandra); about 75% worse (2-5 ns), rest better (2ns)
- Almost all voltages, LLC settings behave differently
- Worse scores in benchmark, from a tiny bit to quite considerably, probably related to memory issues
- Weird stalls under the main Windows install, feels much slower
- Fixed SOC Voltage now is a problem, up to reboots during CB20 MT, have to keep in Auto
- VDDP/VDDG at 900/950 is messy now, much lower scores
Annoying... probably source of some other issues like swinging scores.You nailed it!! was going crazy over CB20 reboots until I set the SOC voltage to Auto!
No problem with it. Maybe worth trying flashing from FreeDOS with DMI clear.Is smart fan working for anyone? I can't access the menu in the bios.
Indeed, another reason for the low scores with PBO. They are piling up...F20a
Virtualization is default enabled and can't be disabled.
idk then. i'm still on F12f official and don't have hyper-v enabled. svm was the only setting i toggled and ryzen master complained when SVM was on and didn't when SVM was offA couple notes here.
First, you should always “Load Optimized Defaults”, save and exit, flash the BIOS, and then ”Load Optimized Defaults” again when flashing a BIOS for any motherboard on any architecture. Yes it is possible to dirty flash, but it can create problems, some hidden. A particularly nasty scenario is a case where functionality for an item is present, but the UI option is removed. I have had this happen on both AMD and Intel systems. The only way to really fix things at that point is to open up the case and short the pins. On some boards I even had to remove the battery.
Second, Ryzen Master will launch with SVM enabled, however it won’t launch with Hyper-V enabled.
Certain software enables Windows virtualization at boot. This is what kills Ryzen Master. Ryzen master does not care about SVM, nor should it.idk then. i'm still on F12f official and don't have hyper-v enabled. svm was the only setting i toggled and ryzen master complained when SVM was on and didn't when SVM was offA couple notes here.
First, you should always “Load Optimized Defaultsâ€, save and exit, flash the BIOS, and then â€Load Optimized Defaults†again when flashing a BIOS for any motherboard on any architecture. Yes it is possible to dirty flash, but it can create problems, some hidden. A particularly nasty scenario is a case where functionality for an item is present, but the UI option is removed. I have had this happen on both AMD and Intel systems. The only way to really fix things at that point is to open up the case and short the pins. On some boards I even had to remove the battery.
Second, Ryzen Master will launch with SVM enabled, however it won’️t launch with Hyper-V enabled.
Something like...windows sandbox? I had SVM enabled so I could run sandbox as needed, mainly.Certain software enables Windows virtualization at boot. This is what kills Ryzen Master. Ryzen master does not care about SVM, nor should it.
In order to disable it completely you have to use bcdedit. Merely removing hyper-v doesn’t disable it.
Probably.Something like...windows sandbox? I had SVM enabled so I could run sandbox as needed, mainly.
If this is the master, the easiest way to control BIOS flashing is just put the board into single BIOS mode and use the dip switch to select which is active/flash to whatever version you want to main/backup.Hey guys, few questions for you.
1)Wondering if I should update to F20a from F11 (i'll just be using XMP @ 3600 and maybe enable PBO, nothing else.) I've been having random crashes that I haven't been able to sort (replacement CPU and new set of memory came in today, so i'm going to swap the CPU out.) Will hold off on replacing the memory for now as I have no idea what is causing the crash since I can't replicate it and they're so random.
2) How can I download F11 BIOS on my 2nd BIOS chip and the new BIOS on my 1st chip? That way if there are any issues, I can just go back to F11.
3) What's the best method for upgrading the BIOS (just download the file and run?) Any steps/precautions I need to take?
4) I'm currently using the Gigabyte chipset drivers, is it better to use the AMD drivers? If so, can I just download them over the current chipset drivers?
5) I have v1.1 of the motherboard, do I need to download the drivers/BIOS from the v1.1 page or are they the same as v1.0? I hadn't realized this when I first built my system and downloaded the v1.0 BIOS/drivers, so I don't think it's an issue, but want to make sure.
Sorry, I know I have TONS of questions, but i'm just trying to make sure I do everything right..
