ok thanks
Should anyone see that it is available, please let me know. Thank you!I got this answer from Gigabyte Support. ”There has been a global shortage but in 2-3 weeks some limited stock will arrive Nordics. You may contact the local Gigabyte resellers to check the stock availability.”
So maybe they arent EOL after all?
Top M.2 slot, between CPU and 1st PCIe slotI have a question about the best slot to place my new WD Black SN850 M.2 2TB in the Aorus Extreme. Where should I put it to get the best possible performance and bandwidth?
Thank you! I also have a Gen 3-M.2 that I will have for games. What do you recommend I put that?Top M.2 slot, between CPU and 1st PCIe slot
Thank you! That's the goal!you should get nice speed... the Gen4 run fast.
Thanks for the reminder!and don't forget to take the plastic of the heatblock from the motherboard, when you install your SSD
ah well as I did try 31k that was release later no idea, did not even know there was a j version as we jumped to k from iOfficial Homepage
There is an X570 BIOS F31j
Who has tried it?X570 AORUS XTREME (rev. 1.0) Support | Motherboard - GIGABYTE Global
AMD X570 AORUS Motherboard with Direct 16 Phases Infineon Digital VRM, Fins-Array Heatsink, NanoCarbon Baseplate, Triple PCIe 4.0 M.2 with Thermal Guards, I...www.gigabyte.com
Well I mostly bought it for play. 5000 series shall have to wait. Seems there are more problems than necessary for the moment. And it's a little more money than I want to spend right now. My 3800x is good enough as it is right now but might do a 5000 upgrade next year.sadly you did not find a 5000 series
Yeah i also had a spare 3500 when i build the new system... so i did build it already and just swap the cpu. Otherwise with no CPU and not knowing if i get a 5900x was not funny. Well I had so much luck to even get one.Well I mostly bought it for play. 5000 series shall have to wait. Seems there are more problems than necessary for the moment. And it's a little more money than I want to spend right now. My 3800x is good enough as it is right now but might do a 5000 upgrade next year.
The 4650G might go into another system after testing.
A relative is in need of upgrades so this part will be useful in any case, have some options to switch Ryzen Am4 processors around in several builds if they want to upgrade. Upgrade one build and you have a free processor to upgrade the next one.
