1261 - 1280 of 1347 Posts
Ran OCCT 45m, Medium Data Set, AVX2, 1900/3800 Dual Rank, GDM Enabled, VSOC 1.19, and it passed without WHEA errors: F33c. The context for this is that I can't get the same kit to achieve the same on F32. F33c still is slower than previous bios', Calculator Latency test is still around 55ns (5800X) vs 52.9ns on F32.
Going to keep an eye out for odd behavior. Usually if my sound is acting up it means the vsoc isn't getting enough volts. I just ejected a USB Flash drive and the Windows chime wasn't the same so ...
Spoke too soon. WHEA errors. Went 2 days without an error and this morning one showed in in the Event Viewer log. Increased the vSOC to 1.2v and ran OCCT, an error came up within 5 min. Rrrrrr
Has anyone been having issues with resizable bar? I tried to enable it and it removes all of my drives and won’t boot into windows because it doesn’t see any drives? It only happens when I try to turn on the resizable bar option, I can enable the 4G coding without any issues but it won’t let me turn on resizable bar. I have tried bios F32,F33a and F33c, I have the most recent x570 chipset driver, I have a 5800x and a 6800xt with the latest driver update which came out today. Any ideas would be appreciated.
Cheesebumps!!
Enabling Resize-Bar disables CSM/Legacy boot mode..your drives or specifically your boot drive has to be in UEFI mode to boot up properly..
That seems odd. I've toggled the setting to get rid of the four beep error code that seems to have something to do with the RTX 3080 and it doesn't affect the drive detection at all. CSM is supposed to allow older operating systems or devices to talk to hardware I don't think it necessarily disables UEFI or changes your drive to or from GPT.
Cheesebumps!!
I have gone with this dilemma recently..enabling re-size BAR and above 4G decoding disables CSM no matter what..you can check on this discussion and many users on this Reddit post, and YES, AMD didn't made this clear for users..
https://www.reddit.com/r/Amd/comments/k2p67r
I'm just saying that with it enabled, Win10-64Bit still makes a GPT boot drive and boots from it. With it off, that same GPT Win10-64Bit drive still boots. It does for me. ???
Added a second NVMe drive and the BIOS sees both but I can not get the MB to boot from the new one. I'd like to be able to select one or the other to boot from. The boot selection list only shows the first one.
Some ppl here was saying the card is EOL. Why a rev1.2 so ? :)
Looks like AGESA 1.2.0.1 will bring memory performance back to where it use to be,
I'm not concerned about that. I think Gigabyte already patched that in their 1.2.0.0:
2481308
I use hybrid OC from CTR 2.1 beta.
My CPU Sample is BRONZE, that's why the 1900 doesn't work and that's i used 3 month of my time trying to get the cpu working in OC.
I understand why some ppl are doing nice OC here, they have just a sample GOLD :)
This is not fault of Gigabyte stability of their bios now I know.
Here is my sample core, you can see only 2-3 core is not so good, make the cpu from Gold sample to bronze.
CTR BOOST TESTER RESULTS (test version)
CORE / THREAD / FREQUENCY / VID / TEMPERATURE
C01 T0 F 4776 V 1.476 T 61.7
C01 T1 F 4790 V 1.47 T 61.1
C02 T0 F 4931 V 1.476 T 61.6
C02 T1 F 4927 V 1.474 T 62.8
C03 T0 F 4806 V 1.466 T 59.8
C03 T1 F 4807 V 1.46 T 59.7
C04 T0 F 4793 V 1.458 T 59.7
C04 T1 F 4789 V 1.455 T 58.4
C05 T0 F 4839 V 1.453 T 58.1
C05 T1 F 4835 V 1.45 T 58.7
C06 T0 F 4812 V 1.465 T 60
C06 T1 F 4795 V 1.461 T 60.6
C07 T0 F 4795 V 1.457 T 60.6
C07 T1 F 4806 V 1.455 T 62.5
C08 T0 F 4893 V 1.473 T 61.9
C08 T1 F 4890 V 1.47 T 62.2
C09 T0 F 4636 V 1.475 T 57.9
C09 T1 F 4633 V 1.473 T 58.2
C10 T0 F 4679 V 1.486 T 58.5
C10 T1 F 4680 V 1.479 T 59.3
C11 T0 F 4617 V 1.476 T 57.3
C11 T1 F 4616 V 1.472 T 57.5
C12 T0 F 4693 V 1.483 T 58.8
C12 T1 F 4691 V 1.488 T 60.2
C13 T0 F 4631 V 1.491 T 58.7
C13 T1 F 4640 V 1.488 T 58.8
C14 T0 F 4657 V 1.482 T 58.9
C14 T1 F 4648 V 1.476 T 60.1
C15 T0 F 4592 V 1.467 T 60.1
C15 T1 F 4595 V 1.465 T 60.9
C16 T0 F 4637 V 1.47 T 61
C16 T1 F 4641 V 1.469 T 60.5
2481310
PS: Just a council from all ppl getting real problem with their Ryzen, Try the CTR 2.1 tools and make a diagnose of your CPU and give you interesting infos about the quality of your CPU to be sure the problem is not just that ...
Please Gold or Platinum samplers : What are able to do with it ? :)
@vinz i'm able to reproduce it switching from pre F33c to F33c, it's the bios.
new beta F33d bios with new agesa
F33d seems to have a very small single core improvement in my case.
Latency also a very very small improvement.
Anything extra, I'll take it.
good to hear, i was not testing the last 2 weeks as i did upgrade my case to Corsair 1000D and that was a lot work to take all out and put into new case
haha nice, well the link works but then they will post a new one also ok, so we see what comes
