No, no option to update only one of them, either both or none at all.so its not possible to update the Bios with this one
EFI Intel Gigabit UNDI - 0.0.29
OROM Intel Boot Agent CL - 0.1.16
ok i think i just misunderstood something .... the network driver with EFI Intel Gigabit UNDI - 0.0.29 comes with the OROM Intel Boot Agent CL - 0.1.16 or not? but nvm, the most important part for me is to have the EFI Intel Gigabit UNDI 0.0.29 on the biosNo, no option to update only one of them, either both or none at all.
These are the two options you have, not updated or second, updated.ok i think i just misunderstood something .... the network driver with EFI Intel Gigabit UNDI - 0.0.29 comes with the OROM Intel Boot Agent CL - 0.1.16 or not? but nvm, the most important part for me is to have the EFI Intel Gigabit UNDI 0.0.29 on the bios
Many thanksthe first one is with the newest and the second one with the fastest
ok so does this mean u dont use the Intel UEFI x64 Gigabit Driver 0.0.29 anymore and now only the EFI Intel Gigabit UNDI - 0.1.00 ?These are the two options you have, not updated or second, updated.
Network
[Current version]
EFI Intel Gigabit UNDI - 0.0.19
OROM Intel Boot Agent CL - 0.1.13
[Available version]
-\ for i82579/i217/i218/i219 chips
Yes.ok so does this mean u dont use the Intel UEFI x64 Gigabit Driver 0.0.29 anymore and now only the EFI Intel Gigabit UNDI - 0.1.00 ?
hmm could give it a try, would need to go to Windows then though as MacOS requires some weeks, installed the latest Bios f11n, still same issue.Have you tried with just loading defaults change xmp to profile 1 leave the rest on default, an see what happens?
whats new in master f11o bios? why in official site f11n still newest one?New BIOS...
Xtreme - F9k
Master - F11o
GIGABYTE Latest Beta BIOS - TweakTown Forums
Warning Some of beta BIOSes are still undergoing compatibility testing. GIGABYTE is sharing these BIOSes for testing purposes only and are not meant for general release. If you are not familiar with beta BIOS testing, then please only flash the recommended release BIOSes that are posted on the...www.tweaktownforum.com
To many questions from new member.......whats new in master f11o bios? why in official site f11n still newest one?
where you take this new bios from?
3 small questions - too many? ok understand youTo many questions from new member.......![]()
Answered numerous time....how about you to read previous posts..?3 small questions - too many? ok understand you
The BETA BIOS's that are posted over at Tweaktown rarely have any change logs posted with them. If they are available then stasio will note them. The point about them is for people to test them out and if there is anything problematic, or has been fixed, noted then feedback can be provided.whats new in master f11o bios? why in official site f11n still newest one?
Over time either several more BETA BIOS's may then follow and sometimes that will lead to an final release which only then gets pushed to the official motherboard page for all to use.
The good thing about the Master board is at least it has a dual BIOS feature, I have needed that at times. But that doesn't mean you should use a BETA BIOS unless you are aware of potential issues in doing so.
I understand that it is a little vague but that is how it is. If you are uncomfortable with using an unknown BETA then remain on an official release.
@KedarWolf thanks for what you have done with the F11o BIOS.
What have you found out about F11o so far ?
Looking forward to your finding with F11O, I was super lucky with the Rev2 as the original customer did not go through with this purchase at all.I just received my 3070 GPU and so, as yet, my time has been spent changing over to that card and testing it out.
I will probably test that BIOS out soon. I'm still running a modified F11m version, that works fine, with a 9900k and 5Ghz and a memory overclock.
I will also need to retake several screenshots as you can't restore settings between BIOS's.
You did well I note on being able to get a rev 2 Master 3080, kinda sad for those who have been sold a version 1.
hhmm Why i have on this version only 1080p? I don't have 4K.Z390MasterF11oModded.zip
drive.google.com
