1 - 2 of 2 Posts
I have tried 2 different versions of the f6 bios, the one the board came with & one I pulled off the GB site. The latter seems noticeably better. I tried a version of f7 which is probably the worst of the 3.
Another thing I've noticed is that Touch Bios is not 100%. My board was posting incorrect frequency numbers on startup. No changes after a Touch Bios flash. A flash from the bios fixed the issue.
Anybody have any wisdom on A. how to distinguish the different versions and B. which versions perform the best?
You can check the date they were created through a BIOS editor, but really most of the BIOSes are new. I think the latest BIOS fixed some Touch BIOS issues, but yea its pretty new tech so there are going to be bugs.
You should always flash from the BIOS.
If you are having good luck with F6 the ones you downloaded, then stick with that, youc an also look into beta BIOSes.
1 - 2 of 2 Posts
