1 - 12 of 12 Posts
Hello all,
My girl friend is trying to play games that I bought her, but they aren't running well so she needs a new card.. the question really is,is there anything I could upgrade to from my and 290x and then just give her my card that would be worth it? I have a microcenter in my area and could maybe do a step up when the new cards (that I know nothing about) come out?
Or, should we just get a card for about 150 bucks for her? She wants to be able to play games like dayz, Ark, and a few others..and the 5850 isn't cutting it.
I don't care about brand as long as it's good:)
Thank you for any help!
just pickup a used 290 or 290x for her. should be able to find them used in the 180-230$ range
Maybe just find an on the cheap r9 290?
I think everyone will mention how new GPU's are on the horizon and buying in now may not be the most timely.
User
You should keep your 290X. For 150 bucks you've got a R9 380 on newegg. Granted it's 175 with a 20 bucks rebate.
Otherwise you have a GTX 950 for 145 with a 20 bucks rebate at microcenter. Check pcpartpicker for links.
Reactions: Steroids
Old dog, old tricks
Got mine a 270X. She's happy with it.
Originally Posted by Steroids View Post
Just curious,should we get the 380 or the 950 Nvidia version .. which would be better
380 is much better. It's a bit faster than 960
Reactions: Steroids
Be sure to get the specific model number for it, if you want accurate information as some times just brands or model lines can be a bit misleading
Overclocking Enthusiast
I wanna say the power supply is about 500 or 550, I'll have to double check... thanks for the help! Reps given
can you actually post her full system specs I mean a gpu upgrade would help but i believe those titles are more single threaded it might also be a cpu buttleneck. But most likely a vram issue with the 5850.
1 - 12 of 12 Posts
