Ok, my girlfriend left her moms house for the weekend (she babysits her neice) and when she came back she turned her computer on and it gets stuck on the screen before XP loads that has the blinking _ on it, I honestly don't know why, any help?
I think he means the black screen with the blinking underscore in the top left corner. I don't know how to fix that. I would guess a problem with the hard drive, as it's not loading windows.
Yeah, it sounds like it is trying over and over to read the hard drive, to no avail.
maybe it's a problem with your harddrive. This might help but try to check and make sure the plugs are plugged into it really good. It might not be loading up properly and or there isn't enough power going to it. Just make sure the power plug and cable to the mobo are in perfectly.
Clean Reinstall of Windows, Reset CMOS first though, in the BIOS set the HD to be read first. If nothing works, if you can't install it may be a dead HD.
If it is a SATA drive just tell her to look for the silver thing with the rectangular Red Wire going to it, and the black one with 4 coloured wires. Tell her to remove the Black one, and then plug it back in firmly. Then repeat for the SATA cable.
yeah. There may have been a power surge that screwed up the hard drive. To test this theory, i would say take the hard drive out of her computer and hook it up to yours, or someone else's, to see if you can access the files, and maybe to some error scanning.
cant go over there cause of some drama with my brother but she doesnt know how to reset cmos and its IDE lol
I HAD THIS EXACT PROBLEM! it is your harddrive dont bother trying to put windows on it again it will just keep doing it. buy a new harddrive thats what i had to do. it wouldnt start at all. all i would see was the beginning bios stuff
it's not hard lol... Just tell her to gently remove the battery on the big brown thing inside the comp, the wires are basically the same. Otherwise, if you don't want to deal, then just get a new HD.
probably a dead hard drive then, shes "troubleshooting" with her brother about it, the thing that sucks is she JUST ordered a gpu for it today (it had on-board and we couldn't find the drivers, her brother built it awhile ago and didnt do the drivers for some reason) =/ may be agp 6200 but it was only $27.99 free shipping.
Edit: pretty much confirmed the HDD is dead so yea =/ +rep given to everyone
Overclock.net
