How are you defining stability? Also, are you assuming it's your ram that is not stable?
Honestly it sounds like your MOBO just doesnt wanna do 1066 any more.
Originally Posted by Daegameth ![]() How are you defining stability? Also, are you assuming it's your ram that is not stable? Honestly it sounds like your MOBO just doesnt wanna do 1066 any more. |
Originally Posted by Bloodfire ![]() Could be something other than the RAM. Are you OCing linked or unlinked? Etc. Run memtest 86+ on the 1066 ones, as they should be fine at 1066... |
Originally Posted by 18 is # 1 ![]() The most common cause of instability in 2x2GB kits, is tRFC needs to be quite high ~55+ |
Originally Posted by Acoma_Andy ![]() Are you using 4 or 8GB now? Looks like you tried a lot of things, what are the rest of the system voltages at? |
