Glitchy BIOS
340 Views 4 Replies 3 Participants Last post by  SoulThief
Hi there overclock.net,
I've noticed with the EP45-UD3P bios when you get to the voltage settings in MB tweaker it seems a bit glitchy? The board works fine and changes the voltages fine, I'm just asking if anyone else gets this?
Thanks.
1 - 5 of 5 Posts
Not sure what you mean by glitchy? Which bios version do you have?
As long as it works fine I wouldn't worry about it.
Well its kinda hard to explain. Its when your scrolling through it kinda goes "slow", sorry I really don't know how I can put it any other way. Like you know when your scrolling through you can see where the scroller is at? Well when I go through the voltages that kinda disappears on its way through. Sorry again, I could only really explain it if I showed you what it does. I'm just wondering if any others get this.
Yeah, I believe that's perfectly normal. The bios isn't graphically accelerated.
If you are not sure about the BIOS you could also try updating it, but as far as I know, you are just having a normal BIOS --- nothing to it.
1 - 5 of 5 Posts
