1 - 4 of 4 Posts
So I snatched it out (gross) after about 1 second, if even. I peeled the incipio two part case off, the back cover, battery and sim really quickly ( <30 sec) and got some rice to bury it in. After that I tore open a silica pack and poured it all inside of the battery compartment and then buried all of that in rice again.
I want to note that neither one of the wet indicators were tripped and still look perfectly fine.
Is there any thing else I can do or should I just leave it in there for another day or so?
I don't mean to laugh, but... haha. lesson learned, I guess... don't **** and talk. Anyways, wait a few hours before turning it on, and when you do turn it on, make sure it is plugged into the wall. If it works, but you unplug it and it dies immediately, you may need a new battery. If it doesn't work, take it into the store where you got it (Version, AT&T, Virgin Mobile, etc) and tell them that you dropped it in a bowl of water or something. Good luck, and don't talk while crapping.
1 - 4 of 4 Posts
