GOD DAMN IT! HDD broken...?
467 Views 6 Replies 4 Participants Last post by  error10
It was working find a few hours ago...
Ok I'll start form the start.
I had raid 0. It was being really slow and crap and laggy.
So I took the hdds out and stuffed them into another computer so I can copy everything of mine I had stored over to these hdds.
After many hours of waiting and copying I finally get my computer back together.
Boot it up... Only 2 hdds??? ***?
What the hell is going on? Don't tell me I just copied half my stuff onto a hdd that was on its last leg?
:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley:madsmiley
1 - 7 of 7 Posts
Make sure its enabled in the BIOS and in the boot order.
Also go to disk manager.
Win7- Control Panel>Admin Tools>Computer Management>Disk Management and make sure its initialized and has a letter assigned to the drive.
*Also,if the HDD was bricked it would make some sort of bad sound,two of mine failed before and they made un healthy sounds lol.
I will check that now! I don't have windows installed though. But I'll stick it into another PC to check later on.
EDIT: This one didn't make any sounds, it should of been 100% ok.
EDIT:EDIT: Oh and I'm seeing the HDDs in the windows install screen. Its not showing up in there.
EDIT:EDIT:EDIT:!! Oh and it does show up in the bios. That is all. Have not checked with another computer yet.
If the RAID 'controller' on the other computer isn't exact/very-similar it likely isn't going to function.
I didn't have a raid controller and I'm sticking it all back into the same computer.
It works on other computers anyway so I think its fine?
I'll just install windows and deal with it from there.
Did you make sure a drive letter is assigned in DISK management?
15
No idea; this doesn't make a lot of sense. Take a deep breath and relax. Now after you have relaxed a bit, start from the beginning and tell us exactly what you were doing, with exactly what disks, and exactly what computers, including the model numbers of everything.
1 - 7 of 7 Posts
