1 - 20 of 90 Posts
Go into your bios, increase the Vcore to the max it will handle and the FSB to as high as it can possibly go with the mobo and the same with the multi. Im thinking a nice 5ghz for about 12 seconds!!
Why attempt to possibly destroy a fine CPU
5ghz? No way. He doesnt wannna kill it... He jsut wants a suicide run.
Originally Posted by selectodude
Um...I don't think so. Try 3.2GHz.
It was a joke, a literal SUICIDE run.
Originally Posted by jrabb1920
Theres not many that will do 3.2ghz on air.
He's so close though... and the voltage is not too high.
Originally Posted by NeRoToXeN
Okay here goes Im off to do 290 @1.55
I take no responsability if it explodes!
lmao, now you tell him
Hes prolly crying atm!!
I usually just go up a little at a time, try 3.2 like selectodude said and see what happens. Check the temps after a little while at idle and wait for any crashes.
If everything works fine and nothing bad happens, just go up a little higher or until you feel you're right on the brink.
1 - 20 of 90 Posts
