21 - 40 of 90 Posts
Did you tweek the RAM so it's not buggering your OC?
What speed is the ram @? Now to get it stable, run OCCT and see if you can get through it. Suicide is nice and fun at times but stability is the goal
How can you be at the MAX Vcore with that board, you shouldn't be. What are your settings?
Woot, only ten mhz away!!
Discussion Starter · #31 ·
Here's the voltage settings:
Cpu Vid Starup Value: Startup
Cpu Vid Controll: 1.550v
Cpu Vid Special Controll: Auto
LDT Voltage Controll: 1.20v
Chip Set Voltage Controll: 1.50
DRAM Voltage Controll: 2.80
Ok to increase the Vcore some more you need to start using the % (CPU vid special control). Back off the Vidcontrol a fair bit and up the % then see what vcore you get, you will have to work out the settings and re-boot back into BIOS.
Remember overvolting is never recommended, keep an eye on your temps as overvolting will create a lot more heat.
Take it easy and make sure you have things correct before you boot up.
EDIT- chipset voltage and LDT voltage will help with stability also.
Originally Posted by NeRoToXeN
Thanks
I'm gonna have to try out that voltage setting stuff! I'm not goin for stable I want suicide
I don't care if it's Prime or whatever anymore...if I can run all my benches and do my everyday stuff without problems...It's good in my book
FAST as ****!!!!
READ IT AND WEEP!
BOOYEAH!!!
CPU vid contol: 1.425
Cpu spec: 113%
V.Core 1.60
TEMPS 32 right now...
And who told you to drop the divider...gimme luv
21 - 40 of 90 Posts
