Going for a killer i7 overclock with cold ambient...
352 Views 5 Replies 4 Participants Last post by  BADFASTBUSA
Tonight I plan to set my computer in the window to use some of the very cold outside temps to help me reach a wild overclock to do some benchmarking... It will be in the low 20's outside and I am wondering what I should shoot for as far as overclocks? Lastly, (keeping cpu temps in check, which should be no problem), what is the most cpu volts that i should be able to somewhat safely use in these tests? I would honestly like to shoot for 4.8ghz with HT on with a 21 multi, but I don't know if my board will let me use that high of a BLCK, It should be fun playing with it though!
Is there anything you guys know from experience that I should do to keep things relatively safe, or will I not run into any issues?
-edit, i have successfully benched at 4.440ghz (211x21) so far with 1.41v in the bios (cpuz shows 1.40v with this setting)
1 - 6 of 6 Posts
wow kinda hot for this time of year :O
Its freezing already at night here!
during the day its about 7-8 degrees C..
Good luck
Originally Posted by Diabolical999
eh I'd be worried about moisture
Agreed.
Even though I'm going to take my rig outside this evening, if it's as cold as last night. (-7C).
I'll just put some insulation on the parts that will heat up, the NB, CPU socket, etc.
And thank God it's a really dry cold here.
I'll use lots of paper towels around the cpu and the NB, I am also going to load up XP on another hard drive with nothing on it but a stripped down xp and 3dmark06 to try to get the best scores.
What is the best CCC to use for the highest benchmarking in XP, anyone?
1 - 6 of 6 Posts
